Big electrical issue?
Old Apr 17, 2013 | 06:06 AM
scaldwellk's Avatar
scaldwellk
"Hemroid Harley" is my bikes new name. I had the thing checked out and the battery, I was told, was bad. Well looks like that is not the charging problem. There has to be somethng simple going on here with this hemroid.
What would cause a charging issue at the same time the speedometer stops working? I am at a loss and ready to just push the thing into a landfill and get a Honda.
Old Apr 17, 2013 | 07:01 AM
JohnnyC's Avatar
JohnnyC
Your quite possibly dealing with an issue that is well known in the world of Harley ... Corroded connections. This can cause odd intermittent issues with electrical devices.
I'd at least remove each of the battery terminals and clean any and all corrosion from the battery terminal and the terminal lugs. Polish them up with a wire brush. Next follow the main battery leads to their connection point. Hot should lead to the starter solenoid and the ground could go to the starter case or a frame / engine bolt. Clean these connections too.
Be certain to have a HD service manual for you ride. All the specs and troubleshooting info is really important to have if you wrench your own bike.
Best wishes finding the gremlins.
Old Apr 17, 2013 | 06:45 PM
scaldwellk's Avatar
scaldwellk
Broke down and ordered a voltage regulator. I hope that it is the problem.
Old Apr 18, 2013 | 12:59 AM
Brett0424's Avatar
Brett0424
1st Gear
If your speedo is intermittent, your signals don't cancel and you occasionally have a poor idle your VSS is bad or has a bad ground. Clean your fuses/grounds but my bet is you just have two problems that occurred at about the same time, bad battery and bad VSS. If you've messed with ANYTHING recently that is the first place I'd start looking.
Old Apr 18, 2013 | 04:29 AM
scaldwellk's Avatar
scaldwellk
I hate to sound dumb, but what is VSS?
Old Apr 18, 2013 | 06:15 AM
scaldwellk's Avatar
scaldwellk
Not sure why I did not think of this before?
About a week or two before this issue started I noticed this. I started my bike and pulled it outside. When I was putting on my gloves I noticed that the headlight was bright then dim. It was happening about every three to five secounds. It would go dim for for three to five, bright for three to five. My speedometer did stop working that morning, but started working again. I blew it off and didn't think much of it till now.
Old Apr 18, 2013 | 12:25 PM
elfnyc's Avatar
elfnyc
VSS = vehicle speed sensor
a VSS thats goes bad will effect, speedometer, self cancelling signal lites, and a few other things
Old Apr 18, 2013 | 02:05 PM
scaldwellk's Avatar
scaldwellk
Thanks.
Old Apr 20, 2013 | 02:32 PM
scaldwellk's Avatar
scaldwellk
Think I found the problem. I just don't see how it still had a output.
Old Apr 20, 2013 | 03:42 PM
JohnnyC's Avatar
JohnnyC
Good find!
I see you found the root cause. I thought (later, after my above post) that the VSS was going to fix it.
Because of that I deleted a few paragraphs of my comments above that I thought didn't apply yesterday. In one of the deleted paragraphs I had wrote all about the possibility of the stator and the stinking fluid. Guess I shouldn't have second guessed my original list of possibilities.
