It must be cold outside. Your engine oil has condensation on top and that is likely the cause. This will not harm anything if the bike is riden occasonally, and when riden for a 30 minutes or so, the condensation will burn off. Since the oil tank is not full, it has room for condensation to build up. This is one of the reasons when putting a bike (or car) in storage, it is wise to fill the tank and add Stabil or similar fuel additives.
Avoid the temptation to "start the bike" and run it for a few minutes, as that will actually lead to additional condensation build up. Hopefully you will have a chance to go for a ride soon and the problem will solve itself. If, after riding for 30 minutes and getting the engine up to full operating temp, the oil is "soupy" or foamy, do an oil change.
Never seen ice on a dip stick before but would say YEA, IT'S BAD. I wouldn't even attempt to start it before I changed it! Nothing good can come from moisture blended with oil. I have seen creamy/foamy lubricant before when I hadto overhaul a 4 cyl engine and a rear axle, not fun...
Actually I find this hard to believe. Water is heavier than oil, so any water would either be in the crankcase or very bottom of the Oil Tank. You pullin' our leg here?
That is why water is colder the deeper you go yet it freezes from the surface downward. It does like a flip as it gets that cold.
Thermalsomethingoranother.
Thermocline, is what causes the Flip of the water. But that is in like lakes whatever. The water in a enclosure like a tank is going to be on the bottom of the Oil. In a engine, or Oil tank the volume of water to oil is not going to allow the water to float to the surface to freeze. IMHO
