laydown plate mounts?
Old Apr 12, 2013 | 05:13 PM
shiftace's Avatar
shiftace
Default laydown plate mounts?
Been looming all day on here for a members bike I saw a while back. Think it was a dyna but hell, I don't remember. Could have been a sportster or even a v rod.. Anyways looking for a curved lay down lic plate mount. The one I saw was damn near flush mount it looked. Very low and curved. Looked at kuryakn's site and didn't see the same one, joker machine doesn't have one.. any ideas?
Old Apr 12, 2013 | 05:29 PM
cdkyle's Avatar
cdkyle
You might try Road 6 Customs.
Old Apr 12, 2013 | 05:35 PM
HOTLAP's Avatar
HOTLAP
The stock one is very easy to modify, just take it off and remove the rear bracket part and you can adjust it to any shape & position you like.
If I remember correctly I had to drill one hole to access the mounting screw in order to reinstall it.
Old Apr 12, 2013 | 06:54 PM
BluBeaSSt's Avatar
BluBeaSSt
I have the TC brothers BUT, the light is a big POS. I'm shopping around currently.
Old Apr 12, 2013 | 07:42 PM
Captain Smooth's Avatar
Captain Smooth
Try led sled, road 6 customs , dk customs, figuremachine.com They all have some nice plate mounts.
Old Apr 12, 2013 | 07:44 PM
rickss69's Avatar
rickss69
They are all over ebay cheap.
Old Apr 12, 2013 | 08:23 PM
HarleyScuba's Avatar
HarleyScuba
I hacked off the angle piece from the factory bracket.
This is the piece you start with:
Cut it about here to remove the angle part:
Drill three holes to match the pattern in your fender into the bracket. Use this piece for a pattern:
I drilled two new holes in the bracket that the license plate bolts to about here (the license plate no longer bolts onto the bracket using the slots)
I placed three rubber grommets in the fender holes to lift the assembly off my fender and protect my paint. The telephone pole in front of my house is about the perfect radius. Massage your license plate, your newly fabricated bracket and 10 dollar chrome license frame into the desired radius. The bracket gets screwed to the fender. Then, I cut an allen wrench short to reach under the bracket to secure the license plate and chrome frame to the bracket using button head bolts (because the head is shallow) with some washers and big-*** acorn nuts on top. I put a towel between the fender and the bracket in case I got sloppy with the allen wrench during assembly. At night, the tail light provides adequate illumination.
I think it looks pretty good with a lay-down tail light. YMMV
My new plate:
Old Apr 12, 2013 | 08:40 PM
rickss69's Avatar
rickss69
There you go! Won't get much cheaper than that.
Old Apr 13, 2013 | 12:59 AM
FlatIron's Avatar
FlatIron
I don't know how flush you want it or if you want it specifically on the back on the bike but I had this made for me. Although www.ledsled.com has a very similar setup, I just didn't wanna dish out $100 but theirs is cnc'd aluminum so it's worth it.
Jameson
Jan 8, 2015 06:43 PM
Jersey Drew
Sep 13, 2014 10:14 PM
RPG485
Apr 13, 2014 08:30 PM
JakeInMa
Mar 1, 2009 10:57 AM
joechief
Nov 16, 2008 09:51 PM
