Engine stalls or will not idle when hot
Old Feb 19, 2007 | 07:59 PM
herky's Avatar
herky
3rd Gear
Default RE: Engine stalls or will not idle when hot
The dealer said they adjusted the idle speed only, bike is operating as designed.Also check for intake leak, none found. I agree with you regarding their ability to solve the prblem
Old Feb 19, 2007 | 08:05 PM
herky's Avatar
herky
3rd Gear
Thanks for the advise. The dealer already check for intake leak, none found. The dealer picked up the bike, since I am at home without a ride back. I offered to drive to the dealership and duplicate the problem for them. They haven't responded back to me.
Old Feb 19, 2007 | 08:07 PM
herky's Avatar
herky
3rd Gear
Yes, it is the second time for this problem
Old May 31, 2008 | 01:14 AM
Lodi's Avatar
Lodi
Stage IV
I have a 2003 and have the same problem. Taken it in to two shops with no results. Items that I've replaced include the following: fuel petcock, screamin' eagle intake, battery, 42mm mikuni carb, spark plugs, drained gas, regularly serviced, and ignitiontimingplate. When I replaced the timing plate, I did have about two months of successful riding. However, I'm back to sqaure one, which leads me to believe that there is a related problem elsewhere. I've found multiple forum listings that have solved this problem. One was the replacement of the coil, and the other was the replacement of the ignition module. My next move is going to be swaping an ignition coil with a buddy of mine. I'll let you know how it goes!
berniemc
Jun 16, 2015 10:06 PM
Jerry Nokes
Engine Mechanical Topics
Oct 29, 2014 09:50 PM
mmeddle1
Apr 2, 2012 04:05 PM
theghostinsideofyou
Feb 19, 2009 12:04 AM
Blazer
Jun 1, 2006 11:03 PM
