Loose swingarm bolt
Old Apr 28, 2013 | 06:04 AM
Tommy(LiL Hashie)'s Avatar
Tommy(LiL Hashie)
Stage IV
Default Loose swingarm bolt
Yesterday enjoying myself riding around I felt something loose or wobbling,,, when I stopped and looked the bike over I noticed the swingarm bolt was loose and about an inch out of its hole... I carry a few tools so I tightened it up right away... Is this supposed to happen??? I'm being told it needs to be tightened with a torque wrench,,,any suggestions on how much torque is needed or just bring the bike in to the dealer...
Old Apr 28, 2013 | 06:55 AM
Midlife79's Avatar
Midlife79
Rear stabilizer link screw = 25-35 lbs
Is that what you're looking for? I can't find any other values in the service manual that would make sense for what you're describing.
Old Apr 28, 2013 | 07:53 AM
rickss69's Avatar
rickss69
60-70 ft-lbs
Old Apr 28, 2013 | 09:43 AM
Scuba10jdl's Avatar
Scuba10jdl
Originally Posted by rickss69
60-70 ft-lbs
That sounds more like it. Also, the swingarm pivot screw uses red loctite (to prevent this from happening).
Old Apr 28, 2013 | 11:35 AM
grbrown's Avatar
grbrown
Thumbs up
No it shouldn't happen! If you feel able to service your own bike and check these sorts of thing yourself, get a factory service manual, which will have torque settings and a load of other useful stuff. A bonus is that it is a really good read on sleepless nights!
Old Apr 29, 2013 | 07:00 AM
bmxatv's Avatar
bmxatv
check the motor mount bolts too. had one almost back completely out on me.
Old Apr 29, 2013 | 12:16 PM
IRON1250's Avatar
IRON1250
almost without any doubt if your swing arm bolt is loose then the front lower motor mount will be as that is usually the first to loosen.
evobigape
EVO
11
Mar 30, 2018 09:41 PM
Rengnath
Mar 1, 2018 06:03 PM
RidemyEVO
EVO
Aug 8, 2010 10:13 PM
robanna
Mar 6, 2010 11:06 AM
reddfoxharley
Sep 4, 2007 09:36 PM
