replacing shifter
Old Apr 28, 2013 | 06:47 PM
Simon Lam's Avatar
Simon Lam
Default replacing shifter
simple question, simple process but for some reason isn't working..
I bought the RSD brass shifter peg but for some reason its not going all the way into the shifter hole. Anyone else ever have an issue replacing their shifter?
Mine is only going halfway through..and then after that I can't turn it anymore nor can I use any tools or else I ruin the shifter.
Old Apr 28, 2013 | 08:01 PM
iwantmybeerbackplease's Avatar
I've replaced the shifter peg without any issues. It sounds like you may have it cross threaded?
-Beer
Old Apr 28, 2013 | 08:13 PM
John Harper's Avatar
John Harper
Do you have the proper thread on the shifter peg? How about tapping it out to fit properly if not?
Maybe wrap a piece of leather around the peg, grip it with channel lock, and turn it in?
John
Old Apr 28, 2013 | 08:17 PM
Sensei Jim's Avatar
Sensei Jim
Sounds like the wrong thread pattern. Pull it out and put both pegs together so the threads are touching and see if they match up. If thats good look at the shifter threads and see if you had it crossed.
Old Apr 28, 2013 | 08:20 PM
HarleyScuba's Avatar
HarleyScuba
If you can't thread it all the way in, you may as well take it out, 'cause it ain't workin'. If you cross threaded it, it may already be f'ed, but you'll have to take the bolt out to fix it. So, take it out and see what's up. Bolt too long? Cross-threaded? Mis-matched threads? WTH? It's a shifter peg.
Old Apr 28, 2013 | 08:32 PM
John Harper
I did not even find a brass shift peg on the RSD website. What is this item?
Whoa, found it, $45 for shift peg? Better hope you did not strip it, the shift lever itself is probably cheaper to replace.
I always heard that trying to remove the original peg was the hardest part, screwing in the new one was easy.
John
Old Apr 29, 2013 | 06:58 PM
Van Buren's Avatar
Van Buren
you own a 48 or 72?
ICE_BREAKER68
Mar 8, 2019 04:31 PM
paulmj
Sep 21, 2015 05:32 PM
VirtualNorm
Jun 29, 2015 05:49 PM
Greg Di
Mar 28, 2013 11:24 AM
Tek74
Feb 13, 2011 12:23 PM
