Help installing front springs 2012 Iron
Old May 1, 2013 | 09:25 AM
rickss69's Avatar
rickss69
Originally Posted by baka1969
For changing out the springs, I can't see how the process of removing the forks from the trees is quicker and more efficient than changing them without removing the forks.
I did forget to mention that removing the handlebars makes it easier. That takes less than a minute. Other than that, removing the fender, caliper and fork tubes doesn't seem like the easiest route.
Like I said before, I have done this several times and found this much easier off the bike. No wrestling with the caps on a bike teetering on a jack and less chance of scarring your tank by trying to balance the bars across it. If one intends to replace the fork fluid take note that later models have done away with the drain screw on the lower legs...no choice but to remove them. Just offering an alternative here.
Old May 1, 2013 | 10:20 AM
baka1969's Avatar
baka1969
I don't know when they removed the drain plugs but my '07 has them. I cover my tank whenever I work on it. Plus, I strap down my bike when it's on the jack. Also, you can pick up a fluid siphon for under $10. As for the caps? I find them quite easy to remove and screw back on if you follow the method I use (which I picked up from this and the XLforums).
I'm not saying your method is bad. What I'm saying is I've done just fine leaving the forks in the trees. YMMV
Old May 1, 2013 | 11:09 AM
Ironrodent's Avatar
Ironrodent
Thanks for all the replies...shouldn't be too bad now. I figured my trusty crescent wrench with the masking tape would do the job. Now just waiting for rear 444's to arrive.
Old May 1, 2013 | 11:13 AM
rickss69's Avatar
rickss69
I think all after '07 have no drain plug. Impossible to flush/clean without removal. I just can't see the balancing act going on and I'm sure you won't see a dealer doing it that way. I've even seen people rig contraptions from the ceiling to hold the bars...what ever you do just do it safely.
MyClassic09
Jan 15, 2014 08:58 PM
Bacon_Grease
May 30, 2013 05:11 PM
JimmieJack
May 18, 2011 05:18 AM
kylant
Jul 20, 2007 10:41 AM
Jetstream
Jan 4, 2007 10:00 PM
