you can adjust your rear shocks they have three settings and usually come on the lowest one you will need a spanner wrench. I would try that first before dumping 200.00 dollars for new shocks , you will need a spanner wrench to adjust the settings . the progressive shaocks have a better dampening rate.
If you don't ride agressively and don't have a sweet thing sitting behind you, then the factory shocks are probably just fine. On the other hand, what is the point of owning a sportster? I would think the factory shocks should be set on notch 2 or maybe 3 for solo. Later model factory shocks have 5 notches. If you are going to ride 2 up then 412 progressives make a real difference.
I put mine on to lower the Bike and had heard that the Progressives were much better shocks. To say they are better is a BIG understatement. They are worlds better. they take all the harshness, the slam outta the bumps. You will not be sorry you upgraded to them I assure you. And if you want some get em from, http://www.trak-tek.com/index.html
I can say without reservation, they are the best 200+ bucks I have spent.
Look under the "Springs" section on this page for a good explanation of how and why they work.
http://www.calsci.com/motorcycleinfo/Suspension.html
[blockquote]Progressively wound springs will compress perhaps 70 pounds for the first inch, 85 pounds for the second inch, 100 pounds for the third inch, and 120 pounds for the fourth inch. This particular spring would be called a 70 / 120 progressive. The idea here is to make your suspension a little softer for small bumps, and firmer for larger bumps. The progressive springs operate at their lowest weight rating until the closest wound coils bind, then as more and more coils bind, they progressively switch to their high weight rating. Progressive springs allow you to have relatively soft springs for the first inch or so to give a very smooth ride, and very firm springs for the last few inches to give solid handling and absorb large bumps. There is a suspension company called "Progressive Suspension" which manufactures shock absorbers and fork springs, but other companies also have progressively wound springs.[/blockquote]
Using 412s on the rear and replacing the fork springs with Progressives turns the Sportster into almost a touring bike. The smoothness of the ride is unbelievable (no jarring, slamming, or other harshness), yet they are not mushy if you want to get hard on it in the twisties. For me, the best money I've spent on the bike.
I owned a 1200S before the 1200R.The stock suspension on the R was very poor vs the S.I installed both the 412s and front springs,what a difference!No one will be sorry if they buy the 412s.
