Normal temp?
Old May 10, 2013 | 02:43 PM
JeffJA's Avatar
JeffJA
Default Normal temp?
Any one know what the "normal" engine temp is on a 1200 FI sporty?
today it was about 79 degree's
my powervision read the ET at 408 and my oil temp guage read about 210, I loaded another tune in the PV and the temp went down to about 388, this was all city riding too.
Old May 10, 2013 | 02:55 PM
JeffJA's Avatar
JeffJA
thanks!
Old May 10, 2013 | 03:16 PM
Rick7938's Avatar
Rick7938
Just returned from a 120 mile ride on my 2006. It's a carb, but the oil temp was 210 just like yours with an 84 deg ambient temp. Sounds normal.
Old May 10, 2013 | 03:20 PM
iwantmybeerbackplease's Avatar
At 79 degrees, my oil temp gauge will read about 170 to 180 after about an hour of city riding. Humidity will also have some effect on oil temp. A lean mixture will cause higher temps.
-Beer
BMCsteve's Avatar
BMCsteve
Thats a little hot but pretty close to what my PV reads. Last weekend it was 90 out, my oil temp was 200 and temp at the heads was high 300s
Old May 10, 2013 | 03:41 PM
HOTLAP's Avatar
HOTLAP
My oil temp used to run in the 210 range in hot city driving too, once I switched to Amsoil it dropped to more like the 190-195 range under the same conditions.
Old May 10, 2013 | 04:33 PM
Scuba10jdl's Avatar
Scuba10jdl
Normal oil temps are 180F-220F. If your bike approaches 240F, you should pull over immediately, shut it down and let it cool.
Old May 10, 2013 | 04:42 PM
IronHyena's Avatar
IronHyena
im confused on this.
does the PV read the head temp?
mine was 310 F on my first test drive today. Is that bad?
Old May 10, 2013 | 06:36 PM
Sierra141's Avatar
Sierra141
Mine reads 200 degrees highway riding, city usually 150 180 oil temps,
2011 Harley 48. I live in the southwest desert.
Old May 10, 2013 | 07:12 PM
HOTLAP's Avatar
HOTLAP
310 oil temp or 310 head temp?
