PCV decel pop fixed
Old May 26, 2013 | 05:15 PM
Otter's Avatar
Otter
Default PCV decel pop fixed
I've had a bit of decel pop ever since I installed my Power Commander V from FuelMoto, which otherwise runs amazingly. I decided to add some fuel to the 0% throttle column to try and see if that helped. The adjustments made were all of the values in the 1500rpm to 4000rpm range in the 0% throttle column. Those values were 0's down low, and 8's up higher. I made them all 15's and sent the map to the PCV. I buttoned it up and went for a ride, and bingo! no more decel pop at all. None! I couldn't make it do it, and I tried pretty hard.
One happy camper here!
Thought I would share just in case anyone else is having the same problem.
Old May 26, 2013 | 05:48 PM
Simon Lam's Avatar
Simon Lam
what other parts do you have? I also have a PCV from fuelmoto but cant get the decel popping to stop
Old May 26, 2013 | 06:41 PM
Otter's Avatar
Otter
I'm running a PM Super Gas AC, and Rush slip-ons with 1.75 baffles. Have you done any map adjustments at all?
Old May 27, 2013 | 12:42 AM
Simon Lam's Avatar
Simon Lam
i asked them to make maps for me and they have sent me a few but all have had some popping..
Old May 27, 2013 | 08:02 AM
Otter's Avatar
Otter
Have YOU made any adjustments to the map? You should try these value adjustments I am betting it'll work for you as well. If you need help figuring out how to do it, PM me and I'll help you out. Over the phone if you need it.
dmpjr
Mar 24, 2013 12:36 PM
RPS1981
Apr 1, 2012 06:58 AM
Watch Guy
Jul 26, 2011 03:44 AM
dohadex
Feb 21, 2011 06:46 AM
rambler43
May 30, 2009 09:51 PM
