Rocker Box Covers - DIY or Dealer??
Old Aug 22, 2013 | 11:27 AM
1200Cdriver's Avatar
1200Cdriver
You went to more trouble than I did. I did not remove the tank, I loosened its bolts and raised the back with a 1" oak piece, I also removed the air cleaner and its back plate. When the rear was done I raised the front of the tank and removed the front stabilizer.
You did very well.
Old Aug 22, 2013 | 02:51 PM
antics22's Avatar
antics22
awesome Wachuko! Just what I needed. :-)
Old Aug 22, 2013 | 03:01 PM
baka1969's Avatar
baka1969
I did remove the tank. I also staggered torquing down the bolts and did them in stages. Meaning I torqued them a little at a time until I reached the final torque figures. It doesn't take much.
Old Aug 22, 2013 | 03:11 PM
wachuko's Avatar
wachuko
Thumbs up
You did very well.
Thank you. Tank removal was easy once you know how to do it. The video helped. I had the time and wanted to make sure I did not scratch anything... so for me, even if there were a bit more steps, this made it easier/less stressful.
wachuko's Avatar
wachuko
Thumbs up
Cool man. Glad it helps. Just paying back what I have learned from this forum.
Old Aug 22, 2013 | 03:14 PM
wachuko's Avatar
wachuko
Thumbs up
Yes, same here. Started with 50 inch-lbs, then 75, 100, and ended with 125 inch-lbs.
And did so in the order that the service manual indicated. The order can be seen in on of the photos in my previous post.
Old Aug 22, 2013 | 03:32 PM
baka1969's Avatar
baka1969
Those are probably the figures I also used. I just don't have the service manual in front of me.
@OP, you stagger and stage the torquing to prevent any warping. I also do the same with the derby cover.
Old Aug 22, 2013 | 04:25 PM
1200Cdriver
Same here, standard four step torquing, made my own wrench for the narrow space. Well, modified and existing wrench.
tbarcia
Oct 25, 2017 01:18 PM
nbduke
May 22, 2013 01:44 PM
EVOrider
EVO
20
Apr 28, 2012 10:32 PM
ramhunter9
May 17, 2011 07:15 PM
brohrs
Feb 1, 2006 10:28 PM
