2003 1200C issues
Old Jun 25, 2013 | 04:48 PM
Bwolfe84's Avatar
Bwolfe84
3rd Gear
Default 2003 1200C issues
Hey all, I have had my XL1200C for about 6 years. A couple of years ago I stored the bike and didn't pull it out of the garage until a couple of weeks ago. Like an idiot, I stored it with gas in the tank. I knew when I pulled it out the gas was going to need changing so I took off the tank, emptied it, and put 2 gallons of fresh gas in. I took the petcock off when I emptied the tank and took it apart and cleaned it. So I go to start it, naturally she doesn't want to start. I take the breather off, spray a little fresh gas in, pull the choke, and she fires up. Sits there about ten minutes, I try to give a little throttle and the motor cuts off. And will not start again. I've sprayed a couple of sprays of gas in the carb like before and nothing. I'm thinking I need to tear the carb down and attempt to clean it, only problem is I've never done it and don't want to f*ck it up. Any other suggestion?
Sorry for the long post!
Old Jun 25, 2013 | 04:54 PM
cHarley's Avatar
cHarley
A carb that sat that long with stale fuel in the bowl, really should be disassembled and cleaned. I'd also put a new set plugs in it.
Old Jun 25, 2013 | 06:59 PM
Bwolfe84's Avatar
Bwolfe84
3rd Gear
Also, I have the V&H Straight Shots and was wondering if the Arlen Ness Big Sucker stage 1 is ok
Old Jun 25, 2013 | 10:16 PM
DOMAPOI's Avatar
DOMAPOI
Here are all the videos you will ever need to clean or do anything else to your carb. Don't try clicking on the "play" arrow on the video, click on the blue underlined link on top of the video and it will take you to all the videos you need.
.1.0.0l8.3595.11097.0.17087.13.12.1.0.0.0.189.1261.6j6.12.0...0.0...1ac.1.11.youtube.Y0C1ZE2Hr-E
SportsterSnow
Jul 6, 2014 04:30 PM
Josepek
Aug 17, 2013 11:36 AM
cerati666
May 6, 2011 09:29 AM
JohnFlorida
Exhaust System Topics
Apr 26, 2011 02:33 PM
Chubbs103
Jan 30, 2011 11:14 AM
