76 - chokes around 3k rpm
Old Aug 16, 2013 | 09:32 PM
Josepek's Avatar
Josepek
Stage I
Default 76 - chokes around 3k rpm
Hi fellow riders
Got myself 76 and i love it. Got few issues to work out but most pressing one is that it seems to want to stall at higher rpms, around 3k.
Thinking about cleaning carburator. Any other ideas would be much appreciated.
Old Aug 16, 2013 | 09:42 PM
Ragnar Danneskjöld's Avatar
Ragnar Danneskjöld
If that gas is good, I would always start with the carb.
Old Aug 17, 2013 | 11:36 AM
grbrown's Avatar
grbrown
It could be a number of things. On an old bike the gas tank may have a lot of dirt in it, clogging the gas tap filter, so drain the tank, remove the gas tap and flush the tank to remove any built up muck. If you do find a lot of dirt, strip and clean the float bowl too, which may even have water in it. If the hoses are very old they may have perished and be blocking flow, so check and if necessary replace them.
That should deal with getting gas to the carb! Float level may be low, a jet may be blocked, or other internal carb problem, so do strip and clean the carb. If it has been on the bike a long time get a rebuild kit, which will have new gaskets and nice new perishable parts.
Let us know how you get on.
joshlewis33
Jul 31, 2015 07:41 PM
SportsterSnow
Jul 6, 2014 04:30 PM
akhdrider
Sep 30, 2012 10:34 PM
paneyes
Panhead
Jan 10, 2010 07:59 PM
Kodster
May 14, 2008 02:09 PM
