led taillight problems
Old Jul 1, 2013 | 05:17 PM
streetrodderbn's Avatar
streetrodderbn
4th Gear
Default led taillight problems
I bought a LED smoked laydown taillight off of Fleabay, Of course it doesn't work correctly, but I can't figure out why. I hooked up the ground wire and the running light wire, and everything worked correctly, but as soon as I connected the brake light wire the running light went out, but the license light stayed lit! when I energized the Brake light circuit, it worked correctly! I dont understand why the running light goes out. The same thing happens if I ground the brake light wire.
Old Jul 1, 2013 | 06:42 PM
BigCheeseStick's Avatar
BigCheeseStick
Sounds like somewhere in the led wiring the brake light wire is grounding out. Is it possible to dismantle things and inspect for where the wire may be grounding?
Old Jul 1, 2013 | 07:06 PM
Mac10's Avatar
Mac10
Yea go through the wires again and make sure they're connected to the right ones. Sounds like your canceling one another. What brand LED did you get. I bought the kuryakyn smoked low profile but it was plug and play.
Old Jul 2, 2013 | 05:50 AM
streetrodderbn
4th Gear
I bought an off brand, I have looked over the wiring, and opened a case on Fleabay. I'll take it apart more today to see if I can get an idea what wiring is wrong.
Old Jul 2, 2013 | 10:03 AM
South JerseyJoe's Avatar
South JerseyJoe
LEDs are positive and negative only. Should be no ground wire. You sure it's a ground wire?
Old Jul 2, 2013 | 03:44 PM
streetrodderbn
4th Gear
the light has 3 wires, a brake light, combination running light and license light, and a ground. I wire streetrods and muscle cars for a living, never heard a light circuit, led or otherwise, that didn't have a power and ground wire..... neither circuit in this taillight works without the ground wire connected.
Old Jul 3, 2013 | 06:38 AM
South JerseyJoe
I use LEDs every day. No grounds needed for 12 volts. Obviously something is not right. I know polarity plays a huge part with LEDs . Check your leads under the seat.
Old Jul 3, 2013 | 08:37 AM
DrewBone's Avatar
DrewBone
From: In the foothills of southwestern NC - US of A
Originally Posted by South JerseyJoe
...No grounds needed for 12 volts...
Huh? All circuits need ground no matter what the voltage. Even if a ground for some reason all of a sudden doesn't exist [through a broken wire or corrosion] the circuit will search and "find" ground through another fixture causing problems such as other lights on the same circuit lighting/blinking dull. The light fixtures that don't have a separate ground wire to attach to an earth ground do so through the fixture to earth ground.
We need a picture or schematic of this fixture and it's attached wiring to figure out what's going on. It may very well be that the wiring is not as expected or the fixture is not as described. Maybe the wiring is fubar'd on the guys bike? Who knows!
This is one reason why I never get anything off of eGay...I've heard too many stories of guys getting hosed with inferior stuff, and to me it's worth paying a little more for things from a reputable seller than taking a risk with off brand iffy stuff, just to save a few $$? Either way I hope the OP gets it running proper.
=8^)
Old Jul 3, 2013 | 12:06 PM
streetrodderbn
4th Gear
I agree, I usually don't buy the junk off ebay. the factory wiring is untouched, just 3 wires going to the light socket, one for the running lights, one for the brake light circuit, and a GROUND! lol I tried every possible combination to get this LED crap to work, with no success . I have a open case on Ebay to solve the case, but still know there is some internal wiring issue with this light, I reinstalled my factory light amd it works as designed. I wire LED turn signals in streetrod dashes all the time, with a 12 volt power source and a ground, so I know there has to be a design flaw that grounds the running light when you touch the red brake light wire to the red brake light wire on the LED light.
Old Jul 3, 2013 | 12:47 PM
DrewBone's Avatar
DrewBone
Are you absolutely sure the third wire is ground?
=8^)
