Detonation is very bad for your engine and will cause damage. try to avoid it. the best way to get rid of it is invest in a tuner you can control without a dyno tune. powervision or thundermax are the best choices but will cost you.
Originally Posted by IRON1250
I did read your sig. my idea of a good tuner is one that will auto tune for changes in climate and elevation to avoid pinging. i've ridden my iron from 35 degrees to 100 without ever having a problem but it would ping constantly with a harley stage 1 flash.
So, you're suggesting he throw out a tuner he's already invested hundreds of dollars in, and spend hundreds more for a different one with auto tune, just to back out 2* of advance during the hot summer months?
Lot's of folks experience the same thing...they are routing the dirty oily air from the breathers back into the combustion chamber.
Many just de-tune the bike by retarding the timing periodically.
You are on the right track running the water to get rid of the carbon build-up.
Once you do, then the next step is to get an air cleaner and breather system that routes that into the atmosphere instead of into your engine. It will run better and last longer.
I'll certainly agree that a breather system and A/C is a good investment, but the idea that that is going to cure the very common problem of pre-detonation in air cooled motors brought on as a result of hot summer temperatures, is quite a stretch.
You must have lots of money to burn..........
well that will work if he is able to back it out. if not what do you suggest? i don't need any more money as i'm going on my 3rd year detonation free without the need to adjust anything. i was simply sharing my experience with harley tuning and pinging and how i cured it. i'm not so sure it is as easy as just changing the timing with efi maps. guess he can have at it is he feels safe doing it.
He already has a SEPST "tuner" which means he can adjust the timing. It shouldn't take more than a few minutes to subtract 2* of advance from the current map and save a copy of the new "summer" map. If you keep the 2 maps on a laptop, it's a pretty simple 5 minute process to upload the summer map at the start of summer, and reload the normal map in the fall.
well i know nothing of that tuner so if he can do it more power to him.
There is no doubt that some pre-det needs to be addressed by a proper tune.
However, the OP said-
I have about 9000 miles on my 1250 conversion, bike runs great andmost of the miles were put on last summer when it was even hotter and I never heard any pinging then.
This is a classic example of the bike running great and then later (in the same or similar conditions) beginning to ping because of carbon build-up.
Almost always carbon build-up is due to the hot dirty oily air being fed back into the combustion chamber.
double post... opps!
Thanks for the replies guys. One of the things I wanted to know was if this is a common problem and it sounds like it may not be common but there are others that have experienced the same issue. Interesting to hear that other people have to change their timing a bit during the hotter time of the year. It will be easy enough to change maps if I find it necessary.
I do think that carbon buildup has something to do with it since I had no pinging last year. One day when I am not spending money on my mountain bike all the time I plan on getting a AC that does not vent into the intake. I do not have oil leaking from my AC but when you pull it off there is oil all over the intake.
This morning before work I spent a few minutes and rolled back my timing between 3 and 5 degrees and it definately seemed to help. Less ping on the way home and the bike still ran very well. I am going to retard it a bit more in the low to mid rpm range through all throttle positions and see if that gets rid of the last bit of ping.
I ran a couple of cups of water through my intake today with a sprayer when the engine was hot but I never saw anything come out of the pipes. No smoke or soot.
If anyone doesn't really think a lot of carbon can build up after 10000 miles, the picture below is of the stock 883 pistons with about 2000 miles on them when I removed them during my 1250 conversion.
