flat tire
Old Jul 18, 2013 | 01:23 PM
riiano's Avatar
riiano
Default flat tire
I took the bike 2012 superllow on vacation, down aroud Corpus Christi, Tx. Got up to day and found flat on rear of bike. Can't find anyone with correct size. Damn hate to load bick in back of truck to take home
Any body know a good shop close that carries any parts? The dealer don't
Old Jul 18, 2013 | 02:00 PM
elfnyc's Avatar
elfnyc
goto walmart or target and get some of that slime in the bike section
Slime 32 Oz SLiME Tire Sealant
quick fix and will get u home
Old Jul 18, 2013 | 02:01 PM
Ragnar Danneskjöld's Avatar
Ragnar Danneskjöld
Can't plug it?
Old Jul 18, 2013 | 02:42 PM
grbrown's Avatar
grbrown
Do the really simple stuff first and check the valve core is in tight. Then check your tyre to see if you can find the cause of the puncture and remove it. Ask the dealer if he can patch repair the tyre if it needs it, that is do a vulcanised repair. If they can't then any auto spares shop should have a can of the slime elfnyc mentioned, also a repair kit so you can plug it as well.
Old Jul 18, 2013 | 04:26 PM
riiano's Avatar
riiano
Found a nail in tire, not sure a bout running 300 miles on tire with the slime inside. But thanks for the ideas
Old Jul 18, 2013 | 04:28 PM
DallasSportster's Avatar
DallasSportster
If its in the middle of the tread you can plug it. Some will say its not safe, but I have put a few thousand on my plugged rear tire. You could also have a shop just install a tube in your tire. That would be the most cost effective and quick options.
Old Jul 18, 2013 | 04:32 PM
cHarley's Avatar
cHarley
+1 - if the nail is in the middle of the tread, plug it and ride.
I always keep a plug kit and mini compressor with me.
TravisD27
Sep 24, 2018 11:12 PM
zachpeed
Jul 22, 2015 12:35 PM
Triple M
Oct 31, 2014 06:56 AM
revzhawg
May 13, 2010 08:53 AM
Lincoln33
Dec 7, 2007 07:28 PM
