Progressive lowering kit
Old Jul 25, 2013 | 08:58 PM
370H55V's Avatar
370H55V
6th Gear
Default Progressive lowering kit
About four months ago I installed progressive lowering shocks, I was going to do the front and rear but the shop I ordered them through recommended just doing the rear until I got used to the ground clearance? Anyway, Im getting ready to do the front now but was wondering if anyone has front and rear and if it makes a big change that I should keep an eye on more than normal. Thanks
Old Jul 25, 2013 | 09:23 PM
PanHeadRich's Avatar
PanHeadRich
IMO it makes no sense that they didn't want to do the front as well, WTF? The only changes it makes is highly favorable. I'd be surprised if the handling is even noticeable to you, other than improved ride quality. Do the front' you'll be glad you did. And maybe start getting advice from another shop.
Old Jul 25, 2013 | 11:44 PM
jolee1118's Avatar
jolee1118
5th Gear
Now that you had the rare shock for four months... you will be able to tell what kinda improvement there is with front changed. I bet you'll regret you didn't do it years ago.. ^^
Old Jul 26, 2013 | 07:15 PM
RickRock's Avatar
RickRock
Like you 370, I lowered rear first, but only rode around for couple days. I found it stiffer but more comfortable for me, because of the lower center of gravity. It seemed like it was harder to maneuver when backing out of spaces, and turning around when doing the duck waddle thing. Lowered the front; and it made that stuff easier. Felt way better riding too. I let a teeny bit of air of back tire and its all good. I ride on the conservative side so I can avoid potholes, etc. If you like it now, you'll love it when you're done. You may want to take some before and after measurements (ground clearance and shock travel) to look back on if adjustments are needed later.
Old Jul 29, 2013 | 01:04 PM
370H55V's Avatar
370H55V
6th Gear
Thanks for the advice, yeah looking back now it doesnt make any sense and im going elsewhere for my advice now for sure.
Old Jul 29, 2013 | 01:06 PM
370H55V's Avatar
370H55V
6th Gear
I will definitely take the measurements, and keep that in mind thanks. What part of Maine are you from?
Dan h
2014-2024 Touring Models
16
Oct 14, 2022 04:13 PM
DynaCaps9
Jul 6, 2018 04:35 PM
MartinSporti
Jul 19, 2014 12:02 PM
richie
Apr 6, 2013 03:55 PM
schumacher
Feb 6, 2010 07:36 PM
