Engine Knock when Cold
Old Aug 24, 2005 | 10:13 PM
custom1200's Avatar
custom1200
Stage III
Default Engine Knock when Cold
I have a 2000 1200 sportster, When i first start the engine it has a knock. I haven't pinpointed exactley where it is coming from. When the engine is warmed up the knock goes away. I haven't been able to figure out what this is. I anyone can help it owuld be great. Thanks
Old Aug 24, 2005 | 10:17 PM
LordVngr's Avatar
LordVngr
Default RE: Engine Knock when Cold
Where I come from Any Knock coming from a motor is No Good and usually means Problems. Since the bike is a 2000 it's probably out of warrenty so I think you should take it to a dealer / independent, Have them diagnose it and then go from there. Not much help I know buts thats how I would probably handle it.
LV
Old Aug 25, 2005 | 02:16 AM
mikeisglidn's Avatar
mikeisglidn
most engines will knock a little when cold. the severity of the knock depends on mileage, engine wear and oil vescosity. not really much to worry about, but you may want to let the bike warm up a little before you gag the throtle!!
Old Aug 25, 2005 | 07:56 AM
oldgeezer's Avatar
oldgeezer
Had a similar knock on my Softail. Turned out to be a loose nut on the compensator sprocket in the front of the primary. You have to pull the outer primary cover to check it and when you pull the outer, you need to replace the gasket as they are a one shot deal. Good luck.
cuda67bnl
Aug 20, 2009 07:43 AM
Hd fanatikz
Oct 17, 2008 04:21 AM
DenimStreet
Sep 3, 2007 12:32 AM
custom1200
Exhaust System Topics
Aug 28, 2005 06:22 PM
custom1200
Aug 26, 2005 08:59 PM
