Baker Drivetrain
Old Sep 5, 2013 | 07:52 AM
j.james's Avatar
j.james
6th Gear
Default Baker Drivetrain
I saw that baker made a 6-speed transmission kit for the sporty but the years it fits are throwing me off (91-03). Were there any changes made in 04+ to the transmission that would not make it work? I was hoping it would still work with my iron. if not ill just swap it for a xl1200r trans.
Old Sep 5, 2013 | 08:01 AM
Scuba10jdl's Avatar
Scuba10jdl
It will not. They made a LOT of changes between the solid mount transmissions and the current models. No trap door, helical gears, case redesign, layout redesign.
Old Sep 5, 2013 | 11:51 AM
j.james's Avatar
j.james
6th Gear
so if i want a six speed my only viable option would be to take one off a xr1200? that seems like it should work in theory (as long as its the same model year of course)
Old Sep 5, 2013 | 12:01 PM
cHarley's Avatar
cHarley
On the 2004 and later Sporties, the tranny and motor are a single unit. You cannot remove or replace the tranny as a unit. To repair the tranny on your bike requires the complete dis-assembly of the motor and the splitting apart of the motor cases.
This is why Baker or no one else makes replacement trannies for the 2004 and later bikes.
Old Sep 5, 2013 | 02:27 PM
John Harper's Avatar
John Harper
I think you can change your primary chain drive ratio as well as your final (belt) drive ratios if you know which direction you want to go. Might be much cheaper and easier than splitting the cases. Or, just sell your bike and buy a 1200r if that is what you desire.
JOhn
Old Sep 5, 2013 | 02:32 PM
aswracing's Avatar
aswracing
The XR1200's are 5-speeds as well. All Sportsters since '91 have been 5-speeds.
As Charley mentioned, in 2004 they did away with the trap door, and servicing the trans means a full tear down and splitting the cases. No longer can you have the trans out in 30 minutes.
The gears and shafts remained largely the same for 2004, but they went to a new & improved dual rail shifter arrangement, that first appeared on the XB's a year earlier. I can't see how you could get a Baker 6-speed into one, since the Baker has it's own shift drum and fork arrangement. I don't see how you could make it fit. It's a whole different animal.
In 2006, HD changed everything again. Practically every part of the trans got changed, shafts, gears, shift arrangement. They went to a helix cut on the trans gears to make them run quieter.
Bottom line, you can't get there from here. You want a 6-speed, you need to get a 91-03 bike and then fork out another $2300 to get the trans.
Old Sep 5, 2013 | 02:41 PM
parabellum_9x19's Avatar
parabellum_9x19
Do you mind us asking why you want the 6th gear this much?
Not trolling, genuinely curious.
I have both a 6 speed and 5 speed bike (Yamaha FZ6 and an Iron 883) and I honestly don't see the 6th gear as being very useful.
Old Sep 5, 2013 | 08:18 PM
j.james's Avatar
j.james
6th Gear
i was just curious if it could be done. my friend owns a fabrication shop and he wasnt sure if it could be done. plus i saw a "6" on my speedo that looks like it could light up, i thought it was for the ellusive sixth gear.
brandon95354
Apr 29, 2013 05:26 PM
Cowboydan
Jul 8, 2012 12:27 AM
guitarman023
Apr 28, 2009 06:20 AM
SC-Longhair
Jan 7, 2009 01:29 PM
rockerhead
Jul 19, 2008 09:08 AM
