Ride height;
Old Sep 14, 2013 | 08:45 AM
Holywater's Avatar
Holywater
Default Ride height;
My nightsters stance is stock right now. I'd like to lift it an inch or two. I'm a big boy. So stiffer suspension would help. But in the areas I ride in I'd just like to have an inch or two higher stance.
So, i know the rear shocks are 11''. But I have no idea about fork components. Outside of the fact that they are 39mm. How long are the legs? and if i wanted to add an inch or two, what parts would I need??
Thanks all.
Old Sep 14, 2013 | 09:06 AM
Mac10's Avatar
Mac10
Thanks all.
You can throw on longer shocks, that will raise you. Maybe 13's
Old Sep 14, 2013 | 09:12 AM
Holywater's Avatar
Holywater
Thank you. I already planned on 13 inch rears. But what about the forks? If I stick to the original height forks and just get stiffer springs, how will that affect the handling and stance?
Old Sep 14, 2013 | 11:34 AM
grbrown's Avatar
grbrown
I have done the same to my SuperLow. I used 13" rear shocks, but the front was easy. You may find when you sit on the bike the forks sag over half of their full travel, mine did. I used Race Tech single-rate springs, matched to my svelte form (check their website), and set the sag correct. That lifted the front around an inch. The longer shocks don't ride 2" higher, but rather less, due to having a longer stroke, hence sagging more than the stock short ones.
Old Sep 14, 2013 | 12:26 PM
modular's Avatar
modular
grbrown speaks gospel. I have done the same thing on my scoot. This is a very good way to go. The only thing I can add is going with a pair of preload adjustable fork caps.
Old Sep 14, 2013 | 01:21 PM
grbrown's Avatar
grbrown
Cool
Aw shucks!
Thanks! Now what more can you tell us about your pre-load fork caps?
Old Sep 14, 2013 | 01:56 PM
lewk's Avatar
lewk
Holywater,
Check out this thread by baka1969 to see what some of us did to raise our front end: https://www.hdforums.com/forum/sport...mfortable.html
Old Sep 14, 2013 | 04:35 PM
modular's Avatar
modular
I personally went with the Roland Sands Design caps in chrome. Linky: http://www.rolandsands.com/products/...39mm-black-ops
Old Sep 14, 2013 | 05:22 PM
grbrown's Avatar
grbrown
Thumbs up
Thanks for that link - very interesting!
samhallnc
Jul 30, 2012 06:36 PM
bbqbrisket
Nov 23, 2011 06:26 PM
MikeSz
Aug 13, 2010 06:10 PM
Ramboamt
Jan 11, 2009 07:47 PM
dsuppa
Aug 29, 2006 08:07 PM
