Old Sep 14, 2013 | 06:02 PM
Koooouuumar's Avatar
Koooouuumar
6th Gear
Default ?
Might be stupid question but thought I will give it a try. Helped a buddy change rear head gasket on his 2007 1200 sportster. Everything went good except now there is a excessive tapping (almost a knock) in the rocker box. What did we miss? Took it back apart and everything looks ok.
Old Sep 14, 2013 | 06:27 PM
Afghanvet_2x's Avatar
Afghanvet_2x
Did you let the lifters pump back up, or possibly switch the push rods? The push rods are different.
Old Sep 14, 2013 | 06:31 PM
Koooouuumar
6th Gear
Thanks for the reply..... Put push rods back in correct tubes.... How do you prime lifters? We poured oil in lifter tubes and run engine for a few minutes. What is the proper way to prime them?
Old Sep 14, 2013 | 07:41 PM
John Harper's Avatar
John Harper
Is it possible that the top rocker box cover got turned 180? I have the three piece boxes, I think yours is a two piece, but maybe it can go in reversed, I'm not really sure.
I have read something about letting the lifters bleed down, but I would think if you had the head off for any appreciable time, all lingering oil pressure would be gone. Who knows.
John
Old Sep 15, 2013 | 11:01 AM
Afghanvet_2x
you just let them sit until you can turn the push rod with your fingers, that what my service manual says. takes about 30 minutes. If that doesn't fix it I would double check installation.
Old Sep 15, 2013 | 12:32 PM
Koooouuumar
6th Gear
Thanks for the reply.. Think we have it now. Ram out of daylight yesterday so we let it sit overnight. Fired it up this morning and all seems good now!! And know more oil leak!!!
Old Sep 15, 2013 | 05:26 PM
Afghanvet_2x
Glad you got it fixed, the lifter probably just had to bleed down.
adm
Engine Mechanical Topics
Feb 1, 2016 01:56 PM
MacKo2000
Apr 27, 2014 10:54 AM
phase17
Jan 25, 2014 08:39 AM
tootal
Exhaust System Topics
Mar 3, 2011 05:09 PM
clove07
Shovelhead
Jun 17, 2010 07:03 AM
