engine and primary fluids
Old Sep 17, 2013 | 02:33 PM
cHarley's Avatar
cHarley
Originally Posted by Kontankerous
Only issue I have with using or recommending Mobil 1 75w-90 is it does not say it's safe for yellow metals. Since our trans/primary share the lube, you're washing your stator in a potential yellow metal UNsafe lub.
I guess you missed The Memo..........
Old Sep 17, 2013 | 02:47 PM
Kontankerous's Avatar
Kontankerous
holy crap, I never even noticed that and I'm a Amsoil reseller. I guess I just never looked to see cause I never thought to personally use it. I put Severe Gear in all my bikes as well as any other that comes in the shop, unless they specifically ask for another.
Thanks for pointing that out...and yes, I did miss the memo
Old Sep 17, 2013 | 02:48 PM
BMCsteve's Avatar
BMCsteve
Here is why I run Red Line MT-90 (a GL4 lube) and not M1 -
1) Mobil themselves state that their GL5 can be harmful to yellow metals - http://www.mobiloil.com/USA-English/..._Gear_Oil.aspx
2) The cited study found here - https://www.hdforums.com/forum/sport...-answered.html to my knowledge was done testing the oil out of the bottle, not in real world conditions. You wont run into issues with most GL5 oils until they are exposed to heat and moisture at which point it becomes corrosive. Both of which exist in your primary.
3) According to this study - http://www.lastgreatroadtrip.com/wp-...comparison.pdf Mobil 1 is NOT MT-1 rated. MT-1 calls for a higher level of oxidation stability, which Mobil 1 does not support.
Some of the Buell guys blamed failed stators on the Mobil GL5. You can run it and you might no have any problems but there's no way its going in my bike
Old Sep 17, 2013 | 02:56 PM
Kontankerous
you can see in the Amsoil data during the heat oxidation test that Mobil 1 actually outperformed Redline 75W-90 in the foam test and the viscosity percentage change. I don't know for sure if that 75W-90 is equatable to the MT-90 or not.
However, i've always steered clear of Mobil 1, because of my shop experience with those that have brought things in that have been running Mobil 1 oils. It could be standard wear on the part and more frequent use of Mobil 1 throughout the population as coincidence but, I stay away from it.
Old Sep 17, 2013 | 03:00 PM
BMCsteve's Avatar
BMCsteve
It definitely could outperform Red Line in those tests. Keep in mind, none of these tests apply to our primaries and transmissions. You can really run anything that is the correct weight and be fine as far as the gear oil holding up. That's why Formula+ works fine and its a basic mineral oil with almost no additives.
For me I know that the MT-90 can handle way more than our primaries could ever throw at it and there is no chance of any issues with the yellow metals
Old Sep 17, 2013 | 03:11 PM
cHarley's Avatar
cHarley
In the study you're quoting, M1 passes both the New and Aged oxidation testing.
Time has also proven that the M1 is not responsible for stator failures, crappy HD stators are, as the failure rate is no higher with the M1 than it is with Harley's Formula+.
Old Sep 17, 2013 | 03:42 PM
Scuba10jdl's Avatar
Scuba10jdl
I wouldn't worry too much about the yellow metals issue. The primary concern when it comes to that is phosphor-bronze gears. The (in)active sulfur reaction weakens the gear faces causing accelerated wear, and in extreme cases galling/pitting.
None of that even goes on in our transmissions. It's something that was an issue 5 years ago but has largely been surpassed with modern oils and wasn't an issue with us to begin with.
Mobil1 can't recommend it because they didn't design it for that purpose explicitly, simple as that. Just like they tell me I can't run the 15W-50 auto oil in my engine sump; you know, because a Harley engine is soooo much different than any other pushrod OHV engine (cough, SBC, cough).
Old Sep 17, 2013 | 03:59 PM
BMCsteve's Avatar
BMCsteve
Here is one of the threads from the Buell guys discussing how M1 can fail the stators - http://www.badweatherbikers.com/buel...38/549747.html
"I had a stator failure on my S3 using Mobil-1 gear oil. When I replaced the stator, the one obvious thing that was wrong was the potting material around the solder joints (where the external leads connected to the stator windings) was severely deteriorated. It maybe that something in the gear oil attacks this stuff (epoxy or something similar) letting the leads short out and causing the failure."
Old Sep 17, 2013 | 05:20 PM
cHarley's Avatar
cHarley
Sorry, but your "source" is nothing more than another internet forum where the posters are making unsubstantiated claims that have no basis in scientific fact or testing.
The following samples (from your source) could have easily come from a parrot.
You should not use their GL-5 products as it could attack red metals like the stator. (Red metals in the stator? Yea, I believe this guy)
Yes, GL-5 gear oils are known to eat the stators.
(All GL-5's? How about, it's been scientifically proven SOME GL-5 oils can be harmful)
You've been provided with links to scientific test data on various GL-5 oils, some of which like M1, have past with flying colors, and others that have not. Interestingly, you seem choose to ignore the scientific test data in lieu of unfounded wives tales found on an internet forum.
Then there's your own experience with a stator in which the problem appeared to be the deterioration of the epoxy potting compound. That's certainly not a "yellow metal" related issue, and the first claim I've seen that GL-5 attacks epoxy.
The good news is that it's a free country and you have lots of products to choose from.
Old Sep 17, 2013 | 05:38 PM
BMCsteve's Avatar
BMCsteve
No offence but the best evidence I have is the fact that you went through 3 stators in 63k miles
As you said:
Stator #3 just took a dump after only 13,000 miles.
#1 @ 24,000 miles
#2 @ 50,000 miles
#3 @ 63,000 miles
That's enough proof for me
