engine and primary fluids
Old Sep 17, 2013 | 10:43 AM
groverhd's Avatar
groverhd
Default engine and primary fluids
I have been trying to understand this entire debate on sportsters. i guess cause its time for me to change my oil but after doing a Google search i am still kinda lost on what is best. 2011 sportster 48. 6k on it
Old Sep 17, 2013 | 11:10 AM
BMCsteve's Avatar
BMCsteve
There is no "best" other than the correct weight and viscosity.
That being said, I have used Mobil 1, Amsoil, Syn3 and Red Line. Syn 3 was the worst (oil was disappearing) and Red Line was the best and what I still use. It quieted my top end, dropped my oil temp and the level never changes.
For your primary, the Harley Formula+ is what is recommended by HD and it works fine. You can use that, wet clutch compatible engine oil (any of the above will work) or gear lube.
Most will recommend a synthetic gear lube. Again, I use Red Line MT90 and it's been fantastic
Old Sep 17, 2013 | 11:42 AM
Scuba10jdl's Avatar
Scuba10jdl
Attachment 291647
Old Sep 17, 2013 | 11:54 AM
parabellum_9x19's Avatar
parabellum_9x19
Originally Posted by Scuba10jdl
Thread over.
Old Sep 17, 2013 | 01:17 PM
groverhd's Avatar
groverhd
Originally Posted by parabellum_9x19
Thread over.
So its better than hd brand? cheaper or just better?
Old Sep 17, 2013 | 01:20 PM
parabellum_9x19
There is only ONE way to know which oil is better for your bike.
Run one oil for exactly X miles (not less than 3000) and then have it sent to a lab and tested.
Then run the next oil for the same miles, same conditions, and send it off also.
Compare the lab results, they will tell you which is better.
Anything less than lab testing and you/we/I are guessing.
I have had my oil analyzed by a lab for every vehicle I have ever owned, so I know *exactly* if the oil I chose is working.
Here you go, stop guessing and do it:
http://www.blackstone-labs.com/free-test-kits.php
Old Sep 17, 2013 | 01:26 PM
Scuba10jdl's Avatar
Scuba10jdl
Yes.
Old Sep 17, 2013 | 01:46 PM
cHarley's Avatar
cHarley
Nothing special about the HD brand oil other than getting a mediocre oil at a sky high price.
HD's synthetic motor oil, Syn3, is made by Citgo.
Old Sep 17, 2013 | 02:17 PM
Kontankerous's Avatar
Kontankerous
Only issue I have with using or recommending Mobil 1 75w-90 is it does not say it's safe for yellow metals. Since our trans/primary share the lube, you're washing your stator in a potential yellow metal UNsafe lub.
Old Sep 17, 2013 | 02:33 PM
Scuba10jdl's Avatar
Scuba10jdl
Give this a browse: http://www.lastgreatroadtrip.com/wp-...comparison.pdf
