Michelin Commander II report
Old Sep 28, 2013 | 06:05 PM
  #31
cHarley's Avatar
cHarley
Originally Posted by 1200Cdriver
Thanks cHarley, I did some searching and all I found was a vague suggestion to use the stock Dunlop pressure. I blocked my bike up near verticle and then got down on the floor and it was obvious that the foot print of the CII was longer and the sides bulged slightly more than the 401 which suggested to me that the CII has a softer carcass.
That's the thing, which Dunlops? Note the difference in the chart for the Dunlop E3's compared to the 401's.
Old Sep 28, 2013 | 06:15 PM
  #32
1200Cdriver's Avatar
1200Cdriver
True that, so many brain strainers for something as simple as a tire or maybe they're not so simple.
Old Sep 28, 2013 | 06:53 PM
  #33
Dozer40's Avatar
Dozer40
I put one on the front of the bagger before my Sturgis trip. I purposely followed the tar snakes and they were hands down more stable than the Dunlop. This year was the first time with good weather both directions on this annual ride, so I can't really comment on monsoon handling. They have about 5K now.
Old Sep 28, 2013 | 09:43 PM
  #34
Wildon883R's Avatar
Wildon883R
Originally Posted by aces&8s
18,000 mi with a dunlop??? Those tires must not be touching the ground like in trailoring it. What are they on a Mopad? Dunlops are crappy milage by my experience, the worst.
Actually your wrong. I had over 11k and I probably had over half of the tread left when I changed them do to age. Dunlop 401s are a firmer, longer lasting tire than some of the other aftermarkets. I expect to get 16k-18k out of my rear and at least the same in the front.
I cruise on mine but if I road raced i'd run a softer set of rubber. I've noticed no tracking or handling issues with the Dunlop's that many complain about. Dunlop's have been around motorcycles ever since I've been riding and well I'm over half a century mark in age . Oh btw cruising doesn't mean I don't ride the throttle hard
Old Sep 29, 2013 | 09:15 AM
  #35
Scuba10jdl's Avatar
Scuba10jdl
Michelin recommends running OEM pressures on their Commander II's (and all of their tires for bikes actually).
"For use on the road, it’s essential to use the tire pressures recommended by the manufacturer of your motorbike.
You’ll find it in the bike’s handbook or on the machine itself."
And from their fitment guide PDF: "Michelin recommends the tire pressure quoted by the motorcycle manufacturer, except where otherwise stated."
http://www.michelinmotorcycle.com/ad...tire-pressures
www.michelinmotorcycle.com/pubs/fitment2013.pdf‎
Old Sep 29, 2013 | 01:40 PM
  #36
1200Cdriver
That settles it then, I need to stick to 30 PSI even if it "looks" to be not enough.
Old Sep 29, 2013 | 03:49 PM
  #37
cHarley's Avatar
cHarley
That's good info, and it's typical of what I've found in the past when researching Michelin tire data.
What bothers (nags) me, is Michelin's vague recommendation to use the motorcycle manufactures recommended inflation pressures.
Unlike the Commander II which is designed to be used on a fairly broad range of motorcycle brands, the Dunlop 401 is specifically made for Harley, to Harley specifications, and it's designed to be run in most cases, at less pressure than the 401 counterparts, like the Metz 880, Dunlop E3 and Avon Venom.
So, I guess I'm still left questioning whether Michelin's "broad brush" recommendation, is really very accurate.
Old Sep 29, 2013 | 04:25 PM
  #38
Scuba10jdl's Avatar
Scuba10jdl
Yeah, I somewhat get the feeling it is a cover-your-*** (CYA if you will) move from Michelin, but at the same time I can't complain running OEM pressures. I've had some professional experience in off-road tires/motorcycles, and there is always a lot more to it than it appears. I don't doubt Michelin, but at the same time, without running TPMS and a whole host of other data sensors, I really can't disclaim what they say. (Must be the engineer in me.)
I have a few friends from college that went to work for Michelin, so I can't really blame them if what they spec seems odd. The general engineering community really has no reason to lie when it comes to anything like this. I'm happy to run what is recommended.
I've got about 7k on the rear, and I was honestly surprised about that (I had to check my logs) because it still looks brand new, even with a generous amount of 2-up riding. Only time will tell.
As far as I know, Michelin recommends to run OEM pressures. That said, Harley also recommends running their fluids and other stuff, so you know how much we all follow their recommendations.
And 1200Cdriver, mine squeaks when I move it on my smooth concrete garage floor as well. It was a little worrisome at first, because only flats have done that in the past, but it just seems to be a smooth concrete thing. It doesn't do that on any other normal surface.
Old Sep 29, 2013 | 05:08 PM
  #39
1200Cdriver
Yep, I got the, "keep it all Harley" speech at the delivery which went in one ear and out the other
Old Sep 30, 2013 | 02:28 PM
  #40
SportyPig's Avatar
SportyPig
Agreed, there is a difference between tire manufactures and specific models of those tires. My new Ultra Classic of course has Dunlops. They are not the Elite 3 model, but also not the 401 and 403 I've had experience. I can't remember what they are, but they handle much better than any Dunlop tire I've had on a bike in the past.
