Sportsters were designed to "Like" the rpm's. You change the gearing like that and all you'll do is mess up the power you'll need in city driving to get away from those that feel they are more important than you, ie ... the ones that drive a phone booth.
Question - Have you personally tried it? I have and none of those problems you describe exist.
I was new to street bikes in 07 when I purchased my new 08 Nightster. After riding it, I soon joined the "I need a 6th gear" club. And wondered why Harley didn't provide one to our sporties. Answer is :WE DON'T NEED IT. Plain and simple. The Evo engines prefer higher RPMs and it will take some time to get used to it, but in reality, the gearing is PERFECT. The 883 is a little less than the 1200s but that is why if you want more torque or speed, upgrade it to the 1250 kit or just get the 1200 with the better gearing. The other Harleys got the 6 speed tranny because of their weight. Overall gearing should be the same even as the old 4 speeds, just they spaced the shifting to be easier on the RPM "bands". meaning you wont have to wind it out in each gear to get to the next gear effectively. Just my two cents. want more "pep" upgrade the pipes and intake and change your maps. then you will run just fine.
pucker - I have in excess of 100hp in my '07 and I am well used to it. These bikes can easily handle taller gearing, 883 and 1200 alike. You will lose virtually nothing with the swap. You can still turn all the rpm's you desire...you just have the option not to when you want to mpg.
Your bike already has "1200" secondary gearing.
Change to "1200" primary gearing.
Speedometer will not be affected.
I wore a hole in top of my left boot from constantly looking for a higher gear.
That's down to you, nothing to do with gearing! I've owned bikes with 3, 4, 5 and 6 gears and looked for another gear on every one! Stock gearing on all Harleys over the last thirty years has been higher than optimum, to help them meet the EPA noise and emissions regulations. But new riders in particular seem to think it should be increased even further. That is not necessary! Even on a highly tuned bike, stock gearing will be just fine.
Any gearing is just fine on these bikes as long as it suits you. There is no denying that the bikes can easily handle taller gearing and the gains in mpg are real. Been riding since 1966 and I believe I know what I want and what works. I have on hand drive train options for the Sportster that range from the dragstrip to the Salt Flats...each has it's intended purpose and goal in mind.
My '05˝ came with lower gearing than a Nightster or a SuperLow.
Even with "1200" primary, it's still a little low.
Increasing power will only make it seem worse.
No it won't! It will make the bike go quicker and faster! I have lowered gearing on two of my bikes to improve performance, with nothing worse as a result. I changed the compensator on my FXDXT from 25T to 21T - transformed that bike!
