Tallest bars on a 48 with stock cables?
Old Oct 16, 2013 | 01:46 PM
Sweforty8's Avatar
Sweforty8
Originally Posted by cpracing519
I did a 90 at both ends. I think a 60 would be best at the caliper though.
Yep me too, 90 for upper and lower. But i fitted my upper the "reversed" way, meaning the line is going towards the throttle instead of towards the bars. I also agree with you on the fact that a 60 would be better for the lower one but also for the upper or maybe a 30.
So my answer to you BMCsteve is go for a 60 for the lower and a 60 or a 30 for the upper.
Old Oct 16, 2013 | 01:53 PM
BMCsteve's Avatar
BMCsteve
Thanks guys. Looks like I'll go with a 60 for the top and a 60 for the bottom
Old Oct 16, 2013 | 02:18 PM
Sweforty8's Avatar
Sweforty8
No problem dude glad to help out!
Btw I see that you've got a sissy bar on...do you think you could throw in a pic or two in my sissy bar & le pera thread I have going on? Would appreciate it!
Old Feb 16, 2017 | 09:45 PM
BrandonLee's Avatar
BrandonLee
Stage II
Default Cable Extenstions
Thanks for all the great info on what cables that need to be changed. I too plan on installing some Z Top Handlebars.. about a 9 inch rise. My question is I know I may have enough wiring as I have a wire tuck and tank lift, but if I were to run the wires internal to the handlebars, would I still have enough wire length? I noticed the pictures posted had the wires external to the bars. Any info would be greatly appreciated.
Old Sep 5, 2018 | 04:07 PM
AndyB70's Avatar
AndyB70
Stage II
Default 2018 48
hey all,
I’ve a 2018 48 and want to put 10-12” apes on similar to the 48 custom, I’m told I’ll need a full cable/hose kit but reading here maybe not ? Has anyone put these bars on a 2017/18 bike with just a new brake hose ?
Cheers guys
Old Sep 7, 2018 | 12:26 PM
qwikrex's Avatar
qwikrex
6th Gear
I installed Biltwell Frisco's at first on my forty eight. I believe those are a 7-8" rise. Fit fine with all stock wiring and cables, although the brake line was a bit of a stretch. Switched to 10" z apes, all cables reached except stock brake line, which I switched to I believe a 46" line. A 12" bar should be doable I feel with just a brake line swap too, but you may have to get creative with routing the stock length clutch cable.
c.d.lawns@hotmail.com
Jul 15, 2022 01:42 PM
Gnarleydudes80
Dec 4, 2014 02:21 PM
ncarr2492
May 3, 2014 10:20 PM
sickboy949
Aug 14, 2011 09:19 AM
mrcrazynutz
Feb 24, 2010 06:47 PM
