883 sprocket problem,help
Old Oct 20, 2013 | 02:26 PM
gazoh's Avatar
gazoh
4th Gear
Default 883 sprocket problem,help
howdy all
i recently discovered my belt was rubbing on the sprocket cover when releasing the throttle or gearing down,
i removed the sprocover and found that my sprocket has some play because of this crack in the "plate" could someone pls let me know what this plate is called?
i also wanted to ask if this part would be covered by warranty?i bought my 883 in may 2013?
also should i let them repair it or is it a simple fix i could do myself without getting ripped??
thanks a mil
gazoh
south africa
Old Oct 20, 2013 | 02:43 PM
DOMAPOI's Avatar
DOMAPOI
It is called a "Retention Plate" and (I think) part number is 40251-92A. And yes, I would think that it should be covered under warranty and as long as it is covered under warranty the work should be done by the dealer free of charge.
Old Oct 21, 2013 | 03:02 PM
gazoh's Avatar
gazoh
4th Gear
thanks a mil bro
Old Oct 22, 2013 | 06:39 AM
grbrown's Avatar
grbrown
DOMAPOI is quite right! That plate is there to stop the large nut from coming loose. Ask your dealer to look into the rubbing as well.
pedroaruba
Nov 28, 2018 09:30 AM
awilson40
Apr 12, 2016 02:52 PM
bigmant
Aug 9, 2015 01:04 PM
idolno1
Feb 21, 2015 11:42 AM
SuperBrace
Vendor For Sale Classifieds
Mar 11, 2011 11:43 PM
