Idle stall...?
Old Jan 6, 2014 | 05:34 PM
Hellborne82's Avatar
Hellborne82
Default Idle stall...?
I have 2013 Forty-Eight with just over 1300 miles on it. I started her up and let her idle a bit to warm up, and after a min or so, she cut out. She sounded fine, was idling like normal, and then just died. I fired her up again and she was fine...? Any ideas? Anything to be concerned about??
This is my first bike and I'm new to the whole scene, so any words is really appreciated Thanks gents!
Old Jan 6, 2014 | 06:39 PM
Nikotine's Avatar
Nikotine
My 2014 Forty Eight has had a similar issue. I got it brand new with 7 miles and I now have 1900 miles. Since I got it it has had an occational miss around idle to 1800 rpm, not enough to die but enough to audibly hear it skip a beat.
Its all stock except for the short shot slip-ons, never been tuned(yet). BUT this has been happening BEFORE I installed the slip ons. I mentioned it to the dealership when I took it in to deal with an oil leak the first time but they failed to give me an answer or a remedy.
Old Jan 6, 2014 | 08:17 PM
Jester 08 Nightster's Avatar
Jester 08 Nightster
I find this would happen when it comes down of high idle on a cool morning. Use to happen to me all the time, prior to Xied's being installed. Just one of the many things the Xied's made better.
Old Jan 7, 2014 | 12:50 AM
Zenmervolt's Avatar
Zenmervolt
The stock fuel map has a lean point when coming off of cold-start enrichment in certain situations. Without modifying the ECU's open-loop fuel maps (with the Screamin' Eagle tuner) or installing a piggyback system like the Power Commander that has its own open-loop maps, there's really nothing you can do about it.
If the issue is happening once you're in closed-loop, something like the XiEDs will help, but if it's an open-loop issue the XiED won't change anything since the XiEDs only enrich the mixture once the ECU has transitioned into closed-loop operation. This is NOT a knock on the XiEDs, they work very well at what they are designed to do (enrich the mixture when in closed-loop mode), it's just to note that they may or may not help depending on when your bike is specifically having the stumble.
My personal solution was to go in and edit both the open- and closed-loop maps on the ECU directly with the Screamin' Eagle Tuner. I like the flexibility the SE Tuner has that most piggyback systems don't. However, there's nothing wrong with a piggyback system and you can save a bunch of money going that route if you're not in need of the ability to tweak every last little thing.
Old Jan 7, 2014 | 01:47 AM
slyedog's Avatar
slyedog
With my tts it is open loop in idle rpm/map range. I also changed some timing around per suggestion on some good dyno tuners here on the forum. Did you do any timing adjustments as well? Only in the idle range and low map. Also adjusted cold throttle spark in 1k&1.5k up to the next to last temp column. Really help the stumble with a cold take off as well as smoothed it out a lot.
Old Jan 7, 2014 | 01:10 PM
Zenmervolt's Avatar
Zenmervolt
I left the timing alone and stuck with some minor tweaks to the cold start enrichment table when dealing with the stumble. Mine pulled fine when cold, it would just have that "hiccough" once or twice during warmup as I put my gloves and helmet on, so I didn't move things around much when trying to adjust the cold-start behavior.
Old Jan 7, 2014 | 03:09 PM
Hellborne82
As for my stall problem, I didn't change ****...she's bone stock. With that being said, it was ridiculously cold outside, which is why I was letting her idle...then came the stall.
Old Jan 7, 2014 | 05:13 PM
Zenmervolt's Avatar
Zenmervolt
We know. That's why we said there's a problem with the stock fuel maps.
Short of changing the maps or adding a piggyback unit, there's nothing you can do about it.
Old Jan 7, 2014 | 08:02 PM
John Harper's Avatar
John Harper
EFI wussies, try getting a carb bike going in cold weather. My '91 is cantankerous here in San Diego, which is not even that cold.
John
Old Jan 8, 2014 | 01:43 PM
Zenmervolt's Avatar
Zenmervolt
John
You should get that checked out then. A properly adjusted carb shouldn't be that bad. Sure there's a little bit of fiddling with the manual choke (OK, enricher if you want to be technical) as the engine warms up during the first 30-60 seconds, but I've never had a properly cleaned and adjusted (street use) carb setup that I'd call "cantankerous."
The old choke-less racing carbs were indeed cold blooded even when adjusted perfectly, but I doubt someone would be running one of those on the street.
