interchangeable cylinders 02/05
Old Jan 14, 2014 | 01:16 PM
divco13's Avatar
divco13
Default interchangeable cylinders 02/05
Will 05 cylinders fit on a 2002 sportster ?
They were removed from a, 88 ci 2005 Harley Davidson 1200
Attached Thumbnails interchangeable cylinders  02/05-_57.jpg
Old Jan 14, 2014 | 01:43 PM
John Harper's Avatar
John Harper
Are they the large fin style or the small fin? I believe I've read that if you use the large fins on the earlier bikes, you may have to grind away some fin material in some instances.
John
Old Jan 14, 2014 | 01:48 PM
bigpete1's Avatar
bigpete1
that is a twin cam cylinder not a sportster cylinder so answer is no it will not fit on sportster.thanks pete
Old Jan 14, 2014 | 03:04 PM
divco13's Avatar
divco13
Pete thank you for your quick reply.
Anyone have the Part# for the cylinders used on the 02 1200 sportster.
Bob
Old Jan 14, 2014 | 03:07 PM
aswracing's Avatar
aswracing
John
The opposite. A big fin 04-up style XL cylinder will drop right on to an 86-03 bike. However, a small fin 86-03 style cylinder requires some grinding on the lower fin on the pushrod side to clear the pushrod tube bases on a rubber mount. Even though the fins are bigger on the new cylinders, right in that area they're smaller.
Old Jan 14, 2014 | 03:22 PM
divco13's Avatar
divco13
Ok we are getting closer.
What are the part #s used on the 2002 1200.
Large fin or small fin. Model year does not make difference, as long everthing bolts on, a 883C LOWER
Thank again
Bob
Machining is not a problem, as I am a machinist
stonester
Jul 22, 2018 11:38 AM
dr4g0n
Jul 27, 2014 03:53 PM
divco13
May 14, 2014 09:20 PM
divco13
Jan 11, 2014 02:50 PM
Callahan86
Motorcycles For Sale
Feb 6, 2013 07:44 AM
