sportser torque
The 2013 engines had a peak torque value of 79 ft-lbs, and this peak is achieved at 3,250 RPM.
The 2014 engines have a peak torque of only 70 ft-lbs, and this peak is achieved at 3,500 RPM.
The higher compression ratio, combined with a reduction in peak torque and the drift of the torque peak to a slightly higher RPM suggests that the engine has been modified to make it more suitable for high-RPM operation. On the 2013 and earlier engines the torque falls off fairly hard after 4,000 RPM and it would make sense that Harley might be looking to improve the high-RPM performance at the expense of a little bit of low-end torque.
This is just speculation without a full dyno curve for the 2014 engines to look at, but it makes sense.
https://www.hdforums.com/forum/sport...sportster.html
