Best lighting solution ? (Iron 883)
Old Jan 15, 2014 | 11:02 AM
PatoConcha's Avatar
PatoConcha
Default Best lighting solution ? (Iron 883)
Hello,
I would like to get ideas (and pics if possible) about how to get better lighting on an Iron 883 (2014).
I was thinking on get a XENON kit (5.000k or 6.000k) with slim ballast kit ...
Any input on this ?
thanks guys,
Pat
Old Jan 15, 2014 | 12:41 PM
PanHeadRich's Avatar
PanHeadRich
I looked into the HID lights for my bikes, in fact bought a set I never used. I never used it because it looked like more hassle that it was worth to wire up the High Beam. Others I talked with said your don't need it and they just run the low beam. That won't work for me, I need the High Beam for coming up mountain roads at night. So I just gave the HID kit to a friend and bought LED headlamps for both bikes. Though much more expensive than HID, the LED headlamps are simple plug & play.
HID's do kick *** though, I've got them in my Vette and they're great.
Old Jan 15, 2014 | 01:33 PM
slyedog's Avatar
slyedog
http://www.jpcycles.com/product/330-752
Piaa extreme white h4 is much better than stock and way cheaper than hid kit.
Old Jan 15, 2014 | 06:41 PM
PanHeadRich
Those bulbs at JP are a rip-off and can be found on line for about 10 bucks each. They're also twice as much as HID kits on eBay. Here's a HID kit for $23.00 shipped: http://www.ebay.com/itm/OPT7-35w-HID...94f388&vxp=mtr The light output of those bulbs are brighter than stock, but can't possibly be compared to HID. I have some of them laying around here that I've tested. If you go up to 100 watt they start to make a significant difference over stock, but they'll also burn up your H4 Connector & wiring. Bottom line is that no simple bulb will offer nearly as much lighting as HID or LED.
Old Jan 16, 2014 | 04:40 PM
danmannd's Avatar
danmannd
6th Gear
Are the H4 bulbs worth the upgrade? And are they decent for oncoming traffic?
Stiggy
Electrical/Lighting/Alarm
30
Dec 18, 2013 12:41 PM
Sonicgazi
Aug 15, 2013 10:24 PM
jkrahn
Jun 24, 2013 06:39 PM
Jswerve
Touring Parts
Nov 28, 2012 08:04 AM
09sporty
Jul 12, 2011 07:01 PM
