HELP - Part # for 2007 Sportster XL1200C NEUTRAL INDICATOR SWITCH
Old Jan 29, 2014 | 10:32 AM
khong's Avatar
khong
6th Gear
Default HELP - Part # for 2007 Sportster XL1200C NEUTRAL INDICATOR SWITCH
Help me please.
Any one know the part number of the Neutral Indicator Switch that fits 07' XL1200C. My Neutral Light went off even gear was in Neutral. Won't start, of cause.
I ground the wire from the Neutral Indicator Switch and start OK, run fine. I guess the switch is gone or the plug contact is bad. The neutral light went off / on sometimes ago, but today gone dead constantly.
I check through the net and find the following part number "33900-59C" that shoudl fit XL1200C from 1988 + , but some sites say it fits only 1988-1998 or so.
http://www.ebay.com/sch/i.html?_trks...at=0&_from=R40
http://www.bkrider.com/bkrider/SKUSe...eria=C01060343
http://www.kutterharleyonline.com/ha...ator-33900-59c
I can't be sure does it fit my 2007 Sportster XL1200C. Anyone has experience please advise. Thank you in advance.
Wanna to put the switch away, but think it still does some function for safe start. I don't know why this 07 sporty won't even start when clutch is fully pressed.
Old Jan 29, 2014 | 07:58 PM
TonyGinFla's Avatar
TonyGinFla
My 2008 Sportster parts manual shows the neutral switch part number as 33900-99. Based on the suffix, I'd say it works on 1999 to (at least) 2008 models
Old Jan 30, 2014 | 10:36 AM
khong's Avatar
khong
6th Gear
Thank you very much for help. I found this. Also just fixed the clutch switch, working now, pull the clutch and start ok.
fffffish
Apr 14, 2016 05:27 AM
clarkchriston
May 3, 2013 08:23 PM
DravenGSX
Jul 28, 2012 07:30 AM
taggiascoz
Nov 9, 2008 11:39 AM
Von_Zipper
Sep 10, 2008 03:55 PM
