Can anyone tell me what's going on with my rear tire? Look at the rear and you'll see it has a rust sheen on it. No the disc isn't rusty. I'm not sure what gives with it.
One thing I noticed on the stock tire is there are a lot of groves on the side wall where wiping the excess solution off is a pain in the ****, it is better to use a clear solution because your not going to get it all off - when I had my Stock tire on the rear I would clean the rear tire then ride it around the block then wash the bike because the solution that is left in the gaps will spin off and all over the rear of the frame
