just bought a nice bike... now it won't start :(
fortunately, it fired up straight away this morning - no problems at all - so obviously the battery just needed charging
but i do have a couple of quick questions...
- is the optimate harness ok hooked up directly to the battery terminals?
- do you think i could have caused any problems by disconnected/connecting the battery terminals in the wrong order?
thanks
thanks[/quot
OH NOO...the bike will never be right now..your best bet is to sell it before it completely burns up....just kidding it should be fine as long as it started up...and are you sure you didn't leave the key on acc..it is easy enough to do....also you may still need a battery (if I understand you right and you just charged the old one)...just because you charged it does not mean it will continue to maintain a charge...
Harley's are notorious for having battery terminals corrode and loosen up and cause this issue quite often. Also those main cables from the battery connect to frame ground and the starter solenoid, and a main line from the solenoid to the actual starter motor. If any of these are loose or corroded they will block the proper voltage / current from turning the starter, giving you a click, click, click. You must check these connections before you do anything else!
Next would be having the battery tested under load at a auto repair parts or service dealer.
As a rule I always put my battery on a trickle charger overnight, every night, so it's at peak performance everyday. The slightest draw from a radio or clock operating (even in the off position) will lower the batteries ability to spin the starter.
And lastly ... removing the key does not stop the bike from being in the on position or the auxiliary position, unlike a car. The key can be removed in the on / aux. position, so maybe you left the bike on and ran the battery low overnight.
i take it there's no issue having the optimate harness hooked up direct to the battery terminals then? rather than the negative going to the back of the engine block?
cheers
Just checked out an "optimate". It's the name of your charger...lol
It's perfect to connect your harness directly to the battery. Be certain that ground lead connection to the engine is back on very securely. I'd even wire brush any corrosion of the area for the best contact. These are the parts that loosen and corrode, and then give you issues.
The order you must take the connections off are ground first so you can't short it and arc a spark. But it should not effect anything except the surge of the short might effect the radio, or an electronic ignition module. It's running again so the module is working fine.
Good to hear you got it running.
