Horn Relocation Kit Questions
My email address is: jvasiliadis@energizer.com
Thanks for any help you can give!
John
See below for parts assembly diagram (exploded view).
I’m guessing you’ll want these (or fabricate similar):
#6 It’s a chrome bracket
#18 (2) fancy, sorta thick washers
#11 It’s a vibration isolater
#17 goes on bracket mounted to heads
You should be able to use your existing Enrichner Cable bracket that‘s attached to the top of your heads - you’ll just have to cut off the tab that actually holds the cable (as far as I can tell).
The rest of the hardware is typical nuts, bolts and wires.
You can use a “Freeway Blaster” low tone horn for the actual horn. FIAMM Part # 72112. Advance Auto has them (part # 6200015) for $20, but I didn’t research for the cheapest. It will fit under the factory “cow bell” horn cover. I’ve used them as replacements before.
Isolater:
You'll see when you look, your choke **** is probably centered under the valley of the existing bracket that bridges your heads (green circle). On the side-mount horn bracket, the choke is skewed (red circle) and the horn bracket is centered under the main bracket between the cylinders/heads. Also, note that the side-mount horn bracket includes an extra cable guide (also red circle) that's non-existent on your existing choke bracket. It may be superfluous, so that would make fabrication easier. I would think that having the FI bracket with all the other hardware would be a step in the right direction, but there'd be some figurin' and fabrication/alterations going on. I guess you gotta decide what price to effort ratio is tolerable for you. You might look at your existing bracket and figure something out in no time. A drill, saber saw and a belt sander can shape a piece of aluminum pretty easily.
