I got my air shocks installed and I am very happy so far, I only went for a short 20 mile ride so I still need to ride more to see how they perform. Small bumps and potholes are nothing, I barely feel them. The bike feels alot more stable and planted. I am running them with 0 psi, I am about 190lbs. I'm not sure what size they are but the were the same length as my stock shocks. Highly recommend this for an upgrade!
Yeah... seems to be the perfect setting for me as well... I tried 20 psi, 15, 10, 5... I could have left them at 5psi... they feel about the same as 0...
Yeah I didnt put any air in them. I guess no air 0 psi for guys under 200lbs is good. Like I said in my short 20mile ride the bike felt alot better, so I'll prob be good with that, If anything I think its a little too stiff but still 100 times better than the stock shocks. I've heard these shocks really shine for 230lbs ++ guys once they figure out what air pressure to run them.
Wachuko, How much do you weight?
I was 245 when I started riding the 48... 220lbs now and still working on losing a few more pounds... plan is to be at 190-195 and stay there...
I need to check the pressure on the shocks... they might be at 5lbs, can't remember if I left them at 0psi as I was doing several test with different pressure settings.
just out of curiosity, how many people are running their air connections? Are they connecting both shocks to a single air valve, or individual valves on the shocks?
When I bought the shocks the seller sent me everything... so I did the install with the lines and one valve.
I did get the schrader valves just in case I needed to go with an individual setup...
So I guess that it will really depend on what you get. Either way should be fine.
I run mine without the hoses using individual valves. I'm 170 pounds running at 5 psi. I also have a sprung seat and it is a fantastic ride! When I have my wife on board I switch to a sundowner seat and about 20 psi.
I ran a set of these and the bike felt very spongy & I didn't feel very confident on curves while accelerating, just felt kind if wompy. Curious of what past bikes you guys were running, not sure if I am just used to stiff shocks or I may have had a bad pair.
