1987 sportster shifting shaft broke
Old Jun 4, 2014 | 07:26 PM
bikercouple's Avatar
bikercouple
Default 1987 sportster shifting shaft broke
I have a 1987 sportster. I bought it as is. PO said it is stuck in 3rd gear. Pulling transmission out and shifting shaft. At the end of the shaft in the transmission, there is a lil arm that the shaft goes through. Mine has a bead of weld that welds the arm and shaft together, but the weld broke. Can I just welded it back on ??? Right now it just turns around the shaft. There are no grooves or spines it the shift or the arm. It looks like a factor weld.
Thank you,
Bikercouple
Old Jun 5, 2014 | 02:32 PM
John Harper's Avatar
John Harper
I don't see why not, if you find a competent welder. I think a new shifter shaft is about $60.
John
Old Jun 5, 2014 | 03:26 PM
bikercouple
ok I had a friend weld it. he is a welder by trade. We will see how it works out
TRoeger
May 10, 2019 09:40 AM
dndfishing
Oct 13, 2016 06:09 AM
dbernie
Shovelhead
Mar 23, 2016 08:46 PM
Bodean46
Nov 29, 2010 06:57 AM
charlie4x4
Jul 20, 2007 05:07 PM
