Need help
Old Jun 12, 2014 | 10:04 PM
hawaiibooze199's Avatar
hawaiibooze199
Stage I
Default Need help
I am working on a buddies 2011 sportster 1200. We replaced the rear head gasket, both rocker boxes, coil relocation kit, and ignition relocation kit also. After we put it back together it developed a rough idle after it warms up and almost stalls out. I pulled the codes and the only one that came up was P0131 (front oxygen sensor reading low). So I cleared the codes and switched them. The code did not pop back up but is still doing the rough idle after warm up and almost stalling. I has short yappie pipes on it. Any ideas? I am stumped here!!!!
Old Jun 13, 2014 | 10:42 AM
subguy's Avatar
subguy
Check to make sure the throttle body manifold head rubber o-rings are not causing an air leak.
Jesse Masters
Jul 24, 2018 09:31 AM
jbervaldi
Feb 16, 2018 11:45 AM
CalgaryBikeBum
Aug 2, 2016 09:02 PM
hitman1267
Dec 22, 2015 07:40 PM
ta2dave76
Jan 7, 2011 12:42 PM
