First Bike, is this normal?
Old Jun 25, 2014 | 09:08 PM
shiftace's Avatar
shiftace
Shift points.
1st gear. ........ Redline
2nd gear......... Redline
3rd gear........... Redline
4th gear........... Redline
Easy to remember
Old Jun 25, 2014 | 11:47 PM
hpotter's Avatar
hpotter
Smile
Originally Posted by shiftace
Shift points.
Easy to remember
where is Redline?
Old Jun 26, 2014 | 01:56 AM
missedem's Avatar
missedem
if you want to use the book shift points that is fine but the closer you get to the 1 K mileage mark the more you should stretch your motor out. Not hammering it of course but just push it a little harder each time you ride; and vary your RPM . I have been breaking in bikes since 1980 and this philosophy has served me well. If you shift at too low an RPM after the bike is broken in your motor will run like crap and you will get carbon build up in your motor. And at least for me its way boring to run the bike like that all the time. On the flip side you don't need to flog your bike every time you ride it either. The longer you ride the more you will learn to let the bike tell you when it wants to shift.
Old Jun 26, 2014 | 04:16 AM
DavidStiebel's Avatar
DavidStiebel
As this is not a new bike we may assume that the primary chain night need adusting to smooth the ride.
Old Jun 26, 2014 | 05:03 AM
flylock's Avatar
flylock
Before you start making adjustments I would get a service manual and use that to check the specs on it.
Old Jun 26, 2014 | 01:16 PM
RiverSouth's Avatar
RiverSouth
I have the service manual.
I am going to check the chain tension, remove the XIEDs and see if anything changes.
Old Jun 29, 2014 | 07:20 PM
RiverSouth's Avatar
RiverSouth
For any new rider who wonders about the same thing...
I took the bike to the dealer in San Marcos, CA. Brian who handles the rentals got to be the coolest guy you can find at a dealership. He was happy to take it for a ride and found absolutely nothing wrong with the bike. He said I need to get used to it and shift up a little later, on higher rpms.
I had removed the XIEDs this morning but they had nothing to do with it, so I put them back on. The bike noticeably gets hotter without them.
Now I better understand when they say a Japanese bike runs smoother. I rode my neighbors Bolt today. I was looking at the Bolt before I bought the 48. I am glad I didnt go with it. I think the rougher ride adds to the joy of riding. Itls like you buy a horse and then put it on wheels.
And that's why I dont need to change the rear shocks either, or the front. I like it as it is.
The only other change I am going to make is to have it make a little more noise :^)
TimmyPage
Oct 2, 2019 11:49 AM
Falcon195
Jul 1, 2012 12:37 PM
Jon0807
Sep 26, 2011 04:17 PM
tshamba
Apr 7, 2008 11:37 AM
tiger_rider
May 23, 2007 11:20 PM
