HID installation HELP! DDM tuning
DDM tuning installation. Their instructions are a kit for a truck. While it should be self explanatory I have two connections that have no where to go and I am wondering if they sent me the wrong connectors.
I have a 2008 xl 1200 c. I got the hi lo kit so I have the ballast, then I have another "box" they sent me that I assume goes into the battery, It has an inline fuse attached to it. That box has h4 on it.
I took pics, It may be hard to follow but you will see the two connectors in my hand that have no where to go, Everything else is hooked up from the bulb to the ballast, then the ballast to that "h4" box. The only thing left is connecting it to power, then figuring out where the last two go....
Also the connector from the ballast (slim box) is identical between two females coming out of the box labelled H4, how do I know which goes into the ballast(slim box)?
Just guessing here because I can't see the whole wiring system in a single pic, but in the 3rd pic, the connector going to the ballast looks like it should connect to the 2nd headlight, not the ballast. That connector on the ballast looks like should connect to the empty connector on the Hi/Lo box.
Again I may be all wet, but I can't see the whole system. Is there a schematic diagram included?
