Carb pops and sputters
Old Apr 5, 2007 | 02:57 PM
saltlick's Avatar
saltlick
Default RE: Carb pops and sputters
ORIGINAL: Spinder
Would my carb do the same thing if the mix was set too rich? Because my plugs get carbon fouled.
I know there are books for all this, and I have 3 of them open right now, but I keep doubting myself because what I believe needs to be done isn't even being considered by someone who has been mech'in Harleys for years.
Thanks for all the help.
yes, on my old bike (honda CB750) there were mixture screws on each carb (there were 4) and you could start by adjusting those screws. Do they have that on the harley carb? i dont know probably. There is a stock setting im sure, on the hondas you adjusted the screw all the way in til lightly seated, then backed it out 1.5 turns i believe. I was surprised to find out alot of my problm was that, mine was almost all the way in, i adjusted it backout and it ran alot better. Adjusting it in allows less air intake, adjusting it out allows more.
A clogged air filter will also make your bike run rich, a quick check is to take your air filter off the bike completely, run it around the block (not too far) and see about the performance. If your bike has alot more power, and the spits and sputters go away you should first start by getting a new air filter and see if that helps. No filter means alot of air mixing with gas, no more rich problem but who can run without a filter? No one should, all it takes is one stick or rock to total your engine if it gets past the filter into your carb. Its a place to start at least.
pacman552sd
Carburetor Related
Jun 3, 2015 10:39 PM
kenward
Apr 20, 2009 05:09 PM
Bruno2
Mar 2, 2009 08:29 AM
Paulution
Jul 28, 2007 05:28 PM
Beeracuda
Exhaust System Topics
13
Dec 27, 2005 03:16 PM
