Screamin Eagle stage 2 kit, don't waste your money...
At the same time though, I'm thinking the fellow just sold you some snake oil. People are doing heavy modifications to 1200's to get high nineties in power. I think the fellow mostly oversold you on the abilities of the 883 with emissions capable parts and tuning.
I'm not sure, but I have a case open with Harley Davidson direct and will be contacting the dealer tomorrow to discuss what the parts manager told me about this kit. Tell someone this kit will make 100hp and then end up being shy almost 40 whp is def. not going to work in my book.
Melo
Should have done your research before listening to an idiot salesman. Heck even the Harley SE catalog shows the hp/tq numbers of all these kits and I bet it dont say 100 hp.
You need to find a new dealer, call Mile High Harley and talk to their service techs.
Looking at the HP & TQ curves on the dyno chart, makes it obvious there was nothing to be gained over 6000 rpm, as you can see the HP curve has flattened out and even started to drop off a bit. This is good example for why the stage 1 download that raises the rev limiter to 7000 is worthless. Without the proper pieces and parts that play well together and are designed to make power above 6000, there is no performance gain to be had.
The dyno results are typical, if not a little below, of what I usually see for a stock 1200 with good stage 1 mods on a carb bike, EFI usually runs a few HP more (low 70's). It really looks to me like you got a 1200 upgrade with no headwork or cams.
If you're someone who's going to do their own wrenching anyway, this is why Hammer Performance or NRHS makes for a much better choice for performance parts (bang for the buck).
