If I open my derby cover does fluid spill out?
Old Aug 6, 2014 | 07:09 AM
Enzoline's Avatar
Enzoline
Default If I open my derby cover does fluid spill out?
Do I drain it to look in there?
Old Aug 6, 2014 | 07:14 AM
1BRAVO9's Avatar
1BRAVO9
If the bike isn't level some will spill. You should have your motorcycle level on a Motorcycle Jack, lift, or even have someone hold it. If you remove the Derby Cover while on the kick stand yes there is a good chance it will spill.
Old Aug 6, 2014 | 07:47 AM
Super Glidester's Avatar
Super Glidester
If you go on Youtube, I believe the channel is Delboy's Garage, he has a video on Sportster clutch adjustment and you can see that not much oil comes out when removing the Sporty derby cover. There is approximately a quart of oil in the bottom of the primary cover for the chain to run through and it doesn't really come up to the level of the derby cover unless it is overfull. Hope this helps.
Old Aug 6, 2014 | 09:09 AM
John Harper's Avatar
John Harper
Just don't let the magic potato sound genie escape.
John
Old Aug 6, 2014 | 09:14 AM
1200Cdriver's Avatar
1200Cdriver
Only a dribble or two that might be clinging to the inside of the cover. The level should be well below the bottom edge of the opening.
Old Aug 6, 2014 | 09:22 AM
Enzoline's Avatar
Enzoline
Great,thanks.
I'll put a piece of 2x4 under the kick stand
Old Aug 6, 2014 | 09:23 AM
Enzoline's Avatar
Enzoline
John
I almost spit out my coffee, you're awesome
gweissel
Mar 7, 2017 01:28 PM
Hoytclayton
Oil Archive (no new posts)
Jul 10, 2012 05:40 PM
jstorrusten
Aug 22, 2010 10:52 PM
Lone Watie
Apr 14, 2008 05:00 PM
YellowHawk
Dec 28, 2007 01:33 PM
