torque specs
Old Aug 8, 2014 | 11:56 PM
harley7316's Avatar
harley7316
Default torque specs
Hi hoping someone can help me out changing a belt on a 2006 883 sportster for a girl that i know and she moved and cant find her service manual trying to find the torque specs for rear
axle nut and the rear caliper mounting bolts.Thx for the help
Old Aug 9, 2014 | 06:36 AM
mike hawk's Avatar
mike hawk
My 2013 Sportster manual calls for 95-105 ft-lbs for the rear axle nut, and 87-130 in-lbs for caliper to mounting bracket.
Old Aug 9, 2014 | 08:11 AM
harley7316's Avatar
harley7316
Thanks but is a 2006 the same specs?
Old Aug 9, 2014 | 08:23 AM
mike hawk's Avatar
mike hawk
Cannot say for sure... I would assume the specs would be roughly in the same ballpark.
Old Aug 9, 2014 | 08:31 AM
harley7316's Avatar
harley7316
not sure either i know there was 3 different axle sizes 3/4 1inch and 25mm and i cant seem to find the correct specs
Old Aug 9, 2014 | 08:37 AM
mike hawk's Avatar
mike hawk
Hopefully someone else can chime in here for you that has an older manual, just so you can be sure.
I'll bet the specs will be pretty close though, if not identical...
Old Aug 9, 2014 | 08:46 AM
mike hawk's Avatar
mike hawk
If you aren't in a rush, my bud has a Sportster with a manual close to the year of your friends 883. I'll swing by his place later and publish those figures here if he's home.
Old Aug 9, 2014 | 09:12 AM
steelpix's Avatar
steelpix
When they say a torque range of say..95 in lbs to 105 in lbs for example, what do they mean?
Do they mean you want to get to 105 in lbs or keep it at 95 in lbs? How do you know what range to choose?
thx
Old Aug 9, 2014 | 09:25 AM
cHarley's Avatar
cHarley
The correct rear axle torque spec for 2005 - 2007 Sporties, which have a 1" solid rear axle, is 72 - 78 FT-lbs.
The rear caliper bolt pin is 15 - 18 FT-lbs
The rear caliper mounting bracket bolt pin is 87 - 130 IN-lbs
Old Aug 9, 2014 | 10:09 PM
baka1969's Avatar
baka1969
thx
When it comes to torque ranges I usually use the lower end of the published range. That is, unless it calls for a stepped torquing procedure. Then i'll use the middle of the range and at the last step, use the lower end. It's worked for me.
