stock cam question
Old Sep 12, 2014 | 01:50 PM
jcstale's Avatar
jcstale
4th Gear
Default stock cam question
Does anyone know if the stock cams from the 96" engine will work in an 88" engine?
Thanks.
Old Sep 12, 2014 | 01:56 PM
ChickinOnaChain's Avatar
ChickinOnaChain
Big Kahuna HDF Member
Your question didn't belong in the "New Members Area".
It's for introductions. So it was moved in one of the other forums.
Freebirdsride1's Avatar
Freebirdsride1
Welcome from California to the H/D forum New member area
Old Sep 12, 2014 | 02:32 PM
Scuba10jdl's Avatar
Scuba10jdl
MODS: If you see this, this question would do much better in the Touring section instead of the Sportster.
Thanks.
It won't be a direct bolt-in.
The 88" cams press in to the bearings in the cam plate, while the 96" ones are slip fit in the plate itself (no bearings). This makes the journal's on the cam different diameters.
Also, the 88" uses a different style inner chain sprocket than the 96" cams (silent vs roller).
Old Sep 15, 2014 | 12:03 PM
jcstale's Avatar
jcstale
4th Gear
Thanks for the info!
skinman13
Engine Mechanical Topics
25
Mar 20, 2017 02:45 PM
jcstale
Sep 15, 2014 12:01 PM
WellHungWillie
May 15, 2014 10:24 AM
NSCoyote
Dec 12, 2012 01:29 PM
BackRoader
Feb 13, 2011 07:23 AM
