"Missing" pigtail, finally located.
As it turns out, someone rerouted mine to be back by the preload adjuster. The thing is... the wires are routed underneath the little area under the seat and aren't very accessible (or visible) there, and while it was back by the preload adjuster, The plug was darn near flush with the frame, so you'd never really notice it. It was certainly not hanging or anything. In fact, it took some effort to pull it out enough to actually use it. In short, it was very well hidden back there.
I suppose it's not a bad place, if you remember to tuck it back so that it doesn't hang down. If you forget, I don't think it'll touch the rear wheel, but it'll hang out enough to get nasty from everything that wheel spits up, so I ended up rerouting mine to come out just in front of the seat lock cover. That wasn't as easy as it sounds, because as I said, the wires aren't really accessible, but with a little perseverance, I got it done. Now, if I forget to tuck it back, it might vibrate a bit, but at least it'll stay clean.
So... hopefully this helps someone. At worst, I just look like the village idiot for being the only one who didn't know the "obvious" location.
