Sportster S Sportster S Only
Help ! Fault code P1608 & P0523 & P1100
Old Oct 20, 2023 | 05:05 PM
George912's Avatar
George912
Stage II
Default Help ! Fault code P1608 & P0523 & P1100
Hello everyone, I am a new member of the forum, currently my Sportster S 1250 has the following 3 errors: P1608 & P1100 & P0523, and I have replaced the battery with a new one and replaced the oil sensor with a new one. , when I cleared the error and started the engine, the error light immediately turned off, but when I turned off the ignition and turned it back on, it still showed the 3 errors I mentioned above. I would like to ask everyone for their help! Thank you very much
Old Oct 21, 2023 | 11:06 AM
Msquad's Avatar
Msquad
Well, here is what those codes mean if that helps...
P160800 607 Loss of continuous battery Starting and Charging → BATTERY AND 12 VOLT SUPPLY CIRCUIT DIAGNOSTICS
P110000 572 ABS/EHCU indicates torque control fault Serial Data → NO VEHICLE POWER OR LOST COMMUNICATION DTCS
P052300 1036 Engine oil pressure sensor circuit shorted to voltage Instruments → INDICATOR LAMPS
Old Oct 22, 2023 | 02:20 PM
Bafsta's Avatar
Bafsta
change your key fob battery and see if that helps
George912
Oct 20, 2023 01:49 PM
Rooster88
Audio Systems
Oct 5, 2022 05:57 PM
ridemyglide
2014-2024 Touring Models
Sep 26, 2015 02:20 PM
azbob09
Feb 19, 2015 10:51 AM
alazlo
Jun 11, 2007 01:06 PM
