The Dark Side For those members running "Car Tires" on their scoots. This is for their discussion only and not a place for "non dark siders" to mouth off about their negative opinions of this idea!
Happy Dark-Sider
Old Feb 2, 2015 | 08:52 AM
MtTurbo's Avatar
MtTurbo
5th Gear
Default Happy Dark-Sider
Greetings, wanted to stop bye and say Hello! Re-joined the forum as I traded my RK in for a 2014 FLHTK. I was pleasantly surprised to find DS folks on the HD forum.
I been running a Michelin CT on my GoldWing for 3 years now and I "Love It" On my 2nd tire with over 25K on the 1st tire, I picked up a screw so put the new one I had on, while the other one was being repaired, as there is still miles left on old one. Been thinking about going "Double"
Any gotcha's I need to be paying attention too on the setup with the CT on my new FLHTK? I notice some are running a Michelin 205/55Z/16, I have been running a 195/55R-16 Primacy Alpin PA3 ZP Run Flat on the Wing, sounds like this will fit ok on the new HD? Also looking to install a trailer hitch on the HD keeping in mind would be in conjunction with the CT, any suggestions would be appreciated
“There is a principle which is a bar against all information, which is proof against all arguments and which cannot fail to keep a man in everlasting ignorance - that principle is contempt prior to investigation”
Old Feb 2, 2015 | 01:40 PM
tsigwing's Avatar
tsigwing
I went with a 195/60 to keep the overall dimensions closer. I've got a trailer hitch and had no issues with the tire. I chose a receiver style, but there are several out there.
Old Feb 2, 2015 | 02:41 PM
PFWiz's Avatar
PFWiz
I am running a 205-55-16 on my bike, but about 1/2 to 1/3 (I just made this statistic up!) seem to be running 195s. I don't think that you will have trouble with either size.
I do strongly recommend using Ride On tire sealant to balance your car tire with....
Old Feb 5, 2015 | 09:57 AM
MtTurbo's Avatar
MtTurbo
5th Gear
Thanks to all for your Replies, Need to put some miles on the new bike before I swap. "But I will"
I have been using dyna beads and they work well for me. I am curious about the Ride On sealant. How does this feel when the tire is cold. I remember using the green slime in my atv and until the tire warmed up, it felt weird.
Old Feb 5, 2015 | 10:47 AM
PFWiz's Avatar
PFWiz
It seems as to me that after the initial setup the Ride On only moves when the tire is warm and at speed. I have never felt anything strange after the first 20 or 30 miles from initial load.
As I see it, not only does the Ride On balance my tire, but it might save me from a flat! That's a two'fer in my book!
Old Feb 5, 2015 | 02:36 PM
tsigwing's Avatar
tsigwing
Ditto on the ride on. When I mounted my tire I put the ride on in and then waited for two weeks before installing on the bike. The tire set up, so I am sure it all gathered at the bottom. On the initial ride out it did feel funny for about a minute or so. Haven't felt anything strange since.
Johnnypop
The Dark Side
Aug 31, 2019 12:39 AM
Johnnypop
The Dark Side
14
Jul 11, 2019 07:04 AM
E-Rawk924
The Dark Side
Aug 10, 2018 09:13 AM
Grandslam
Jan 13, 2013 01:27 PM
dtgiese
Oct 26, 2010 10:03 AM
