The Dark Side For those members running "Car Tires" on their scoots. This is for their discussion only and not a place for "non dark siders" to mouth off about their negative opinions of this idea!
tire size
Old Jun 1, 2015 | 06:21 PM
Joe Dirt 14's Avatar
Joe Dirt 14
Default tire size
my 2013 ultra limited has a 180/65/16 on the back. what size ct is the best for this size mt? what size are you ultra guys running? Thanks in advance!
Old Jun 7, 2015 | 02:43 PM
rkoivisto's Avatar
rkoivisto
Default 2013 Touring
you can use a 205 or a 195.
I suggest you go with a Michelin Alpin ZP. I think they come in a 195 55 16.
I just went from that to a Yokohama to try something different. I should have stuck with the Alpin.
Old Jun 16, 2015 | 06:58 PM
Rollbar's Avatar
Rollbar
Deleted.... Sorry, wrong post.
Old Feb 4, 2016 | 09:08 AM
ranger351w's Avatar
ranger351w
195 60 16 is about right
Size works real well on my 2013 flhtc.
I have it in Yokahama AVID ASCEND 20K ON IT. Rides good and handles well at 29lbs . Had one on two different bikes, A 2011 RK and the 2013 flhtc.
New on each and around 20k on each one, no flats or problems. Good in rain and dry. Just sayin
Has anyone tried an Kumho Ecsta PA31?
Old Feb 5, 2016 | 04:51 AM
ranger351w's Avatar
ranger351w
What does everyone else use?
Likes dislikes.
Old Feb 6, 2016 | 03:42 PM
jrat69's Avatar
jrat69
I've got the Yokohama Avid Ascend on a 2012 Road King. It's been doing good, getting ready to try the double dark side. Front tire is about worn out.
Old Feb 8, 2016 | 06:36 AM
PFWiz's Avatar
PFWiz
First a little thread hijacking....
I am about to go double dark also, looking at a BattleAx BT-45 in a 150 size. Gonna run it normal direction. How about you?
Now an answer to the OPs question.
I am running a G-Max 205-55-16 with Ride On tire sealant to balance it. My air pressure is 37 psi cold.
Old Feb 10, 2016 | 03:23 PM
tsigwing's Avatar
tsigwing
I run a 195 60 on mine. Forget which brand.
Old Feb 15, 2016 | 04:26 PM
Steve Helton's Avatar
Steve Helton
Likes dislikes.
I have a 2010 rg and have a yokahama run=flat 195-55-16 run 28lbs like it real well.
Old Feb 15, 2016 | 07:07 PM
rkoivisto's Avatar
rkoivisto
Default BattleAxe
I have run several BT45's on the front. The first 4 or 5 I ran in the normal direction, but I was seeing a lot of tearing in the rubber. The last one I had on had a lot of seriously deep gaps where the rubber ripped open. It only had 11K miles on it and still had good tread.
I changed it out and mounted the new one in reverse orientation. I've got 14K on this one and no rips yet. I'm not saying the mounting direction made the difference. I'll have to wait and see.
