The Dark Side For those members running "Car Tires" on their scoots. This is for their discussion only and not a place for "non dark siders" to mouth off about their negative opinions of this idea!
08 Ultra
Old Mar 8, 2019 | 07:41 AM
SBates08's Avatar
SBates08
Default 08 Ultra
I have a riding buddy that is wanting to try out the Dark Side and wanted to see what you guys are using. I've seen the 175-60/16 mentioned in a couple different brands but curious if this size throws the speedo out of whack. I saw this one posted on Facebook. First thought was that's a big difference in height. Your help is much appreciated.
Attachment 597328
Old Mar 8, 2019 | 04:16 PM
smitty901's Avatar
smitty901
Use this sight to match up and compare difference in sizes it work great.
Put in the factory size then the size you are look at Try different ones until you find what you need. Click over lay to see how they match up. It will tell you the speedo differences. Keep in mind not every size you come up with is made so when you find one that works look for a tire. Example not a lot of option in the 195 series. Good luck with your search
https://www.tacomaworld.com/tirecalc...5r16-195-60r16
Cathleen Brill
General Topics/Tech Tips
Mar 16, 2018 12:39 PM
Joe Dirt 14
The Dark Side
14
Mar 4, 2016 06:09 AM
Bunker
Audio Systems
Jan 7, 2016 05:57 PM
Moboy
Oct 5, 2011 11:40 AM
CQCBlades
Sep 7, 2009 09:31 AM
